Delete Layers and Tables From Feature Service (Feature Layer Collection)
5977
6
03-06-2017 12:17 PM
ZacharyNeumann1
So I created a new feature service (Feature Layer Collection) into a folder. It is an empty feature service with layers and table relationships. Each layer has a geometry type. I only want points. How can I delete the line and polygon layers and tables using the ArcGIS API for python? I will continue to read documentation and if I figure it out I will post back here.
ZacharyNeumann1
I think I can use the delete_from_definition(json_dict) method listed here arcgis.features.managers module — arcgis 1.0.1 documentation
I just need to figure out how to use it properly...
JoshuaBixby
MVP Esteemed Contributor
Retrieve the item either by searching or using its unique identifier, and then use the arcgis.gis.Item.delete() method.
ZacharyNeumann1
I will try this next! Thanks Joshua!
ZacharyNeumann1
This makes sense for deleting the feature service completely, but as for deleting its layers or tables it doesn't make sense to me. I can access the object (see comment below this one) but if I use the delete method on the object I get
AttributeError: 'FeatureLayer' object has no attribute 'delete'
If I ask for the object's id I get 1, which is local to the feature service itself.
ZacharyNeumann1
I guess what I mean by feature service is that it's a feature layer collection.
ZacharyNeumann1
Reporting back:
from arcgis.features import FeatureLayerCollection
fs_url = 'URL HERE'
comments = FeatureLayerCollection(fs_url, gis=gis)
layers = comments.layers
tables = comments.tables
for layer in layers:
print(layer)
for table in tables:
print(table)
Output will return each layer and table object.
Tried
del layers[1]
but object does not support item deletion.
ZacharyNeumann1
