Creating workforce assignments using arcgis api for python
2225
09-09-2021 07:23 AM
SpheleleNtilane7
My name is Sphe from South Africa and I am relatively new to programming. I am trying to create workforce assignments using Arcgis Api for python but I am failing.  I have tried using these scripts from workforce-scripts/2 - Importing Assignments.ipynb at master · Esri/workforce-scripts (github.com) but I'm still not winning. I get a Key error when i  try to import my assignments from a csv.
if tolerance is not None:
KeyError: 'Location'
 This is the part of the code that is giving me a major headache:
csv_file = pd.read_csv('C:/Users/sphelele.ntilane/Desktop/Book.csv')
csv_file
csv_file_assignments = []
for index, row in csv_file.iterrows():
geometry = geocode(f"{row['Location']} {row['Suburb']}", out_sr=3857)[0]["location"]
csv_file_assignments.append(
workforce.Assignment(
project,
geometry=geometry,
location=row["Location"],
description=row["Description"],
priority=row["Priority"],
work_order_id=row["Work Order ID"],
assignment_type="No_Water",
status="unassigned"
project.assignments.batch_add(assignments)
Whoever can assist please do
JakeSkinner
Esri Esteemed Contributor
@SpheleleNtilane7 can you provide a sample of the CSV your script is querying?
SpheleleNtilane7
Hi Jake
Its seems pandas in Jupyter notebook  does not recognize columns in my csv and just groups all columns into one.
JakeSkinner
It looks like your CSV is formatted to use a semi-colon (;) as the delimeter.  Pandas defaults to using a comma (,).  When reading the CSV, specify the delimeter parameter.  Ex:
csv_file = pd.read_csv('C:/Users/sphelele.ntilane/Desktop/Book.csv', delimiter=';')
