Create Hosted Feature Layer coded value attribute list using ArcGIS API for Python
4218
6
12-13-2023 12:37 PM
EmmaSchultz1
Hi Community,
I am having issues with trying to create a coded attribute list for a field in a hosted feature layer using python. Here is some background information and some solutions in related posts that I have tried to no avail.
The layer was published directly to AGOL from an .xlsx spreadsheet. I have a script that overwrites the hosted feature layer. When overwriting the hosted feature layer, some of the properties are reset which need to be addressed in the code: Need to make the layer editable again, and need to re-create the attribute list for a field. I need the attribute list to use radio buttons in Field Maps.
Here is the code, everything works great (layer overwrites, capabilities are updated), but when I try to update the feature layer collection definition to create the coded value domain list, it returns:
{'success': True}
 But nothing is changed. No error message or anything.
Full code
#Import Modules
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
print('Modules Imported')
#AGOL variables assigned
user: str = '<username'
pssw = '<password>'
test_itemid = '<itemid>'
test_upload = '<filepath.xlsx>'
#Coded value variables
low_code = 'Low'
low_name = 'Low'
med_code = 'Med'
med_name = 'Med'
#Get the hosted feature layer collection
gis = GIS('<portal_name>', user, pssw)
test_item= gis.content.get(test_itemid)
test_flc = FeatureLayerCollection.fromitem(test_item)
#Overwrite layer and update capabilities with a dictionary
test_flc.manager.overwrite(test_upload)
update_dict1 = {"hasStaticData":False, "capabilities": "Create,Delete,Query,Update,Editing"}
test_flc.manager.update_definition(update_dict1)
print('Updated definition successfully')
#Create a dictionary to use to update the domain list
update_dict2 = {'fields': [{'name': 'Ranking', 'domain': {'type': 'codedValue',
'name': 'Ranking_Domain',
'codedValues': [{'name': med_name,'code': med_code},
{'name': low_name,'code': low_code}]
test_flc.manager.update_definition(update_dict2)
Things I have tried
1) Tried to create a list without Python in AGOL, then tried updating the coded value list to include an additional value. When I create a list in AGOL, then return the domain list it returns the following:
"type": "codedValue",
"name": "Sheet1_Ranking_itemid",
"codedValues": [
"name": "Low",
"code": " Low"
"name": "Med",
"code": " Med "
I then tried to use this default domain name in a script to add another coded value to the list, where it says it was successful but nothing updates. This test was to see if when I use an existing domain name if it would work, as described in the following: Solved: Re: Updating Feature Service Coded Value Domain wi... - Esri Community
The process for updating an already existing domain list in AGOL is also described in here, but they use ArcGIS Pro to update: How To: Edit Read-Only Domains of a Hosted Feature Layer Using Python in ArcGIS Pro (esri.com)
2) Views are locked: I then found the following piece: Solved: Re: Can't edit Hosted Feature Layer Domains in Arc... - Esri Community
It describes an issue where the feature layer views parameters need to be changed, but I could not access the viewLayerDefinition as my layer does not have views.
Solutions?
I am wondering if the issue resides in
1) limitations from publishing the hosted feature layer right to AGOL instead of using Pro. There are a number of questions/ solutions in other posts, but most of them are publishing from Pro.
2) The layer did not have coded value domains when first published - does the layer need a domain list from the beginning in order to update?
3) Is there another parameter/ capability that I need to update in order to enable a domain list on the layer?
Any help would be greatly appreciated! I have been trying this for a few weeks now without a solution.
Clubdebambos
MVP Regular Contributor
Hello @EmmaSchultz1
Domains are not a property of a FeatureLayerCollection, they are the property of a Field in a FeatureLayer so you need to access the feature layer and use the FeatureLayerManager uppdate_definition(). Try the below...
fl = test_item.layers[0] ## ASSUMING ONLY ONE LAYER & ACCESSING IT
field_dict = {
    'name': 'Ranking', ## THE NAME OF THE FIELD TO UPDATE
    'domain': {
        'codedValues': [
                'name': med_name,
                'code': med_code
                'name': low_name,
                'code': low_code
print(fl.manager.update_definition({"fields":[field_dict]}))
~ learn.finaldraftmapping.com
Clubdebambos
Hello @EmmaSchultz1
field_dict = {
    'domain': {
        'codedValues': [
                'name': med_name,
                'code': med_code
                'name': low_name,
                'code': low_code
EmmaSchultz1
Hi @Clubdebambos
First of all, if I could give you 10 Kudos I would.
Again, the difference between FeatureLayer and FeatureLayerCollection has got me! I have read and read documentation on the differences and when to use each but am continually confused. I think my mind was stuck on the fact that to update layer capabilities - "edit, add, delete" etc. this uses the FeatureLayerCollection and creating a domain list in my head is similar to creating a domain field list. I See now that accessing attributes is based on the FeatureLayer and not FeatureLayerCollection.
This has prompt me to do more reading on the differences to wrap my head around this.
I cannot thank you enough for the help.
Emma
StanPlomp
Glen, you rock! Thanks 🙂
MichaelKohler
Hi @Clubdebambos
I'm trying to use this solution to add values to a domain and the success shows true but the domain doesn't get updated. There is a single value in the domain and I'm testing to add more values. I got the domain name from the feature definition
DAZ = gis.content.search("************", "Feature Layer")
lyr = DAZ[0]
fl = FeatureLayerCollection.fromitem(lyr)
field_dict = {
    'name': 'Team', ## THE NAME OF THE FIELD TO UPDATE
    'domain': {
        'name': 'Damage Assessment Zones_Team_2ba4d3f3-73df-4405-87b9-713fd622dac4',
        'codedValues': [
            "name" : "Team 1",
            "code" : "Team 1"
            "name" : "Team 2",
            "code" : "Team 2"
no worries because I'll just update the definition on the admin page but if there are any ideas, I'd appreciate any help.
Clubdebambos
Hi @MichaelKohler
Similar issue as the original post, you are trying to update a FLC when the domain information is in the FeatureLayer.
Your workflow would look similar to the below....
## search always returns a list of Item objects
## accessing the first item of the search list
## assuming this is a Feature Service
fs = DAZ[0]
## accessing the feature layer of interest from the item
## the item must be a Feature Service
## accessing the first layer in the service with [0]
fl = fs.layers[0]
field_dict = {
    'domain': {
        'codedValues': [
            "name" : "Team 1",
            "code" : "Team 1"
            "name" : "Team 2",
            "code" : "Team 2"
Theisen
Would this sample code work in something like I have below? My code is running every 12 hours to make the layer "live". I am reading the item's information and also want to create the domain/maintain it. Currently, every time the code runs, it breaks the domain list I have just in my field settings. I would like to try and set the domain within the code. There is code above this, but this is when I start to create the schema for the hosted table (no spatial data associated with this)
# Append item and group data to the DataFrame
items_df = pd.concat([
          items_df,
          pd.DataFrame([{
                      "Title": item.title,
                      "Item Type": item_type,
                      "Group Names": ", ".join(group_names),
                      "Item Owner": item.owner,
                      "Number of groups": num_groups,
                      "Risk Level": risk_level,
                      "Item ID": item.id,
                       "Item Description": item.description,
                      "Metadata Status": metadata_status,
                      "Content Status": item.content_status,
                       "Relevancy": "",
                      "QC Comments": "",
                      "QC Personnel": "",
                      "QC Date": pd.NaT, # Blank Date Field
           ], ignore_index=True)
# Save the DataFrame to a CSV file for further analysis
sharing_table = 'Hosted_Table.csv'
items_df.to_csv(sharing_table, index=False)
print("Data export complete. File saved as 'Hosted_Table.csv'.")
# Check if the Hosted table already exists in AGOL
existing_item = gis.content.search(query=f'id:{existing_item_id}')
try:
if existing_item:
             # Get the existing Feature Layer Collection
             feature_layer_item = existing_item[0]
             feature_layer_collection = FeatureLayerCollection(feature_layer_item.url, gis)
             # Overwrite the existing feature layer with the new data
             feature_layer_collection.manager.overwrite(sharing_table)
             print("Updated existing feature layer in AGOL.")
     else:
             # Upload the CSV as a new feature layer
             item_properties = {
                     'title': "Hosted Table",
                     'tags': "Item Management",
                     'description': "Hosted Table description."
            feature_layer_item = gis.content.add(item_properties, data=sharing_table, folder="Item_Management")
            # Publish the feature layer
            published_layer = feature_layer_item.publish()
            print("Uploaded new Hosted Table to AGOL.")
