Good afternoon everyone,
We have a folder with 175 .lyr files. All .lyr files are pointing to an SDE instance and we need to change each lyr data source to point to another SDE instance.
I am looking for a way to do that in python where I can loop through all files in the folder and change their datasource.
I think Dan Patterson nailed it - you gotta save the layer file.
lyr.save()
you seem to be missing the except portion of your last try... what happens if it fails?
see my previous comment about saving mxd's... and for sde stuff, does it need to be updated or something if things are shuffling around in there?
Sorry I did not copy paste the exception part of my code:
except Exception as e:
print "Python Error occurred"
#print exception message to the Interactive window
print e
#place error message in geoprocessing messages
arcpy.AddError(e)
logging.error(": %s" % str(e))
sys.exit(1)
except arcpy.ExecuteError:
print "Geoprocessing error occurred"
print arcpy.GetMessages(2)
logging.error(": %s" % arcpy.GetMessages(0))
sys.exit(1)
except:
print "Error occurred"
#print any geoprocessing messages to the Interactive window
#print arcpy.GetMessages(0)
Hi Dan,
This script works fine for the .lyr files that are pointing to a SDE instance that is active. But there are a few that are pointing to an old instance has been retired 2 or 3 years ago. These .lyr file made the program stop
Error Message:
Replace Datasource for xxx.yyy.ProjectLine
Layer: Unexpected error
ERROR: Layer: Unexpected error
ERROR:root:: Layer: Unexpected error
I believe you can check for a broken datasource and skip trying to process it and just put that lyr information into a log file so you can process those lyr files manually.
If you try to access these old SDE instances in ArcCatalog, does it take a long time for ArcCatalog to say that the datasource cannot be found? From past experiences broken SDE datasources can take some time for ArcMap or ArcCatalog to resolve (between 3-40 minutes).
Hi Michael,
Yes it takes very long to right clock on the .lyr and goo to properties to fix the connection for the ones that are broken.
I believe there is an Idea on the ESRI GeoNet to modify ArcMap and/or ArcPro to not attempt to find broken connections for longer than a smaller amount of time (something like 1-2 minutes instead of up to 40 minutes which some endusers experienced).
Hello everyone,
In some cases when I run the line to change the workspace, it does not work. Do variables find_workspace_path and replace_workspace_path need to include the feature dataset or only the connection path?
lyr.findAndReplaceWorkspacePath(find_workspace_path=lyr.workspacePath, replace_workspace_path=r"Database Connections\Esde8_WASDREAD.sde")
lyr.save():
It fails:
These are the values for find_workspace_path and replace_workspace_path:
SValve.lyr
feature class whole path: Database Connections\SQLInstance.sde\Sewer.SewerCollection\Sewer.SValve
find_workspace_path= C:\Users\mydesktop\AppData\Roaming\Esri\Desktop10.2\ArcCatalog\OracleInstance.sde
replace_workspace_path= Database Connections\SQLInstance.sde
You may want to check my python addin /blogs/myAlaskaGIS/2015/08/31/python-addin-for-data-inventory-and-broken-link-repair?sr=search&searc... to see if that will help. Use ass is, if it helps, or take a look at the code if you want something simpler.
