Hello. I'm a python newb and am stumped by the following:
I have a feature class in a file geodatabase. I want to go through each feature in my feature class, find the event code in the Event field, extract the chunk of text after the first "/", and then populate the same row in the Object field with that chunk of text only.
For example, for the first Object ID below, "1", I would like "M1" to populated in the same row in the Object field.
With the event_object = (str(folderpath).split('/')[1]) command, I can successfully find the chunk of text I'm interested in. All that is left is to assign it to the Object field.
Unfortunately, when I attempt to do that, I am somehow stuck with the chunk of text from the last row in the SearchCursor, and it is assigned to the Object field for every feature in the feature class, illustrated in the table data below. There must be something funky with the nature of SearchCursor that I don't understand. How am I grabbing the chunk of text from the last feature in the feature class and getting stuck with it while I'm iterating on features prior to it? How do I defeat this? It's personal now!! Many thanks in advance.
import arcpy
fc = "E:/filegdb.gdb/featureclass"
infield = "Event"
outfield = "Object"
cursor = arcpy.SearchCursor(fc)
row = cursor.next()
while row:
event = (row.getValue(infield))
event_object = (str(event).split('/')[1])
print event_object
row = cursor.next()
arcpy.CalculateField_management(fc,outfield,"'" + event_object + "'",expression_type="PYTHON")
OID,Shape,Event,BeginTime,Object
1,Point Z,MUL201136141671/M1/Points/FCB2S2,2011-12-26 07:35:27,FI9
2,Point Z,MUL201136141671/M2/Points/FCB2S2,2011-12-26 07:35:28,FI9
3,Point Z,MUL201136141671/M3/Points/FCB2S2,2011-12-26 07:35:29,FI9
4,Point Z,MUL201136141671/M4/Points/FCB2S2,2011-12-26 07:35:30,FI9
5,Point Z,MUL201136141671/M5/Points/FCB2S2,2011-12-26 07:35:31,FI9
6,Point Z,MUL201136141671/M6/Points/FCB2S2,2011-12-26 07:35:32,FI9
7,Point Z,MUL201136141671/M7/Points/FCB2S2,2011-12-26 07:35:33,FI9
8,Point Z,MUL201136141671/M8/Points/FCB2S2,2011-12-26 07:35:34,FI9
9,Point Z,MUL201136141671/M9/Points/FCB2S2,2011-12-26 07:35:35,FI9
199,Point Z,MUL201136141671/DT1/Points/FCB2S3,2011-12-26 07:38:58,FI9
200,Point Z,MUL201136141671/DT2/Points/FCB2S3,2011-12-26 07:38:59,FI9
201,Point Z,MUL201136141671/DT3/Points/FCB2S3,2011-12-26 07:39:00,FI9
202,Point Z,MUL201136141671/DT4/Points/FCB2S3,2011-12-26 07:39:01,FI9
203,Point Z,MUL201136141671/DT5/Points/FCB2S3,2011-12-26 07:39:02,FI9
204,Point Z,MUL201136141671/DT6/Points/FCB2S3,2011-12-26 07:39:03,FI9
205,Point Z,MUL201136141671/DT7/Points/FCB2S3,2011-12-26 07:39:04,FI9
206,Point Z,MUL201136141671/DT8/Points/FCB2S3,2011-12-26 07:39:05,FI9
207,Point Z,MUL201136141671/DT9/Points/FCB2S3,2011-12-26 07:39:06,FI9
222,Point Z,MUL201136141671/FI1/Points/FCB2S2,2011-12-26 07:32:00,FI9
223,Point Z,MUL201136141671/FI2/Points/FCB2S2,2011-12-26 07:32:01,FI9
224,Point Z,MUL201136141671/FI3/Points/FCB2S2,2011-12-26 07:32:02,FI9
225,Point Z,MUL201136141671/FI4/Points/FCB2S2,2011-12-26 07:32:03,FI9
226,Point Z,MUL201136141671/FI5/Points/FCB2S2,2011-12-26 07:32:04,FI9
227,Point Z,MUL201136141671/FI6/Points/FCB2S2,2011-12-26 07:32:05,FI9
228,Point Z,MUL201136141671/FI7/Points/FCB2S2,2011-12-26 07:32:06,FI9
229,Point Z,MUL201136141671/FI8/Points/FCB2S2,2011-12-26 07:32:07,FI9
230,Point Z,MUL201136141671/FI9/Points/FCB2S2,2011-12-26 07:32:08,FI9
