Calculate UTM positions using Python?
1639
11-15-2022 02:33 PM
MiltonSolano
Hi Community!
I hope I'm posting on the right forum, if not, help me pointing out the right one.
I have a team capturing Tree locations using Field Maps. These trees have decimal degrees X, Y positions already captured on the fields. I need to automate the calculation for UTM_X and UTM_Y fields for the new trees captured and I would like to setup a Scheduled task in ArcGIS Notebook Script to update these field at the end of the week. Another person from the team export these new trees using a view to an excel spreadsheet for further processing.
Can you help me with the basic python code to start doing this (if it is possible of course). Right now I have to do it in ArcGIS Pro.
Milton
DavidAnderson_1701
Easy.  Use command:
arcpy.management.CalculateGeometryAttributes
It will let you calculate X and Y coordinates in whatever coordinate system you want.
DavidAnderson_1701
Easy.  Use command:
MiltonSolano
Thank you @DavidAnderson_1701 ,
This will work on ArcGIS Pro environment but I need a way to do it in ArcGIS Online, using Notebooks. Thank you for taking the time to answer.
Milton
NicholasGiner1
Hi Milton, you should be able to do this in ArcGIS Online via a scheduled notebook.  To use ArcPy within the notebook, you'll have to choose the Advanced runtime.
thanks!
Nick Giner, Product Manager
