ArcGIS API for Python - XY to Line
1834
02-11-2022 11:42 AM
ChadPeltier
Is there a function in the ArcGIS API for Python for the XY to Line tool (like arcpy's arcpy.management.XYToLine)? I haven't been able to find it in the documentation if it exists.
ChadPeltier
Thanks Dan.
For anyone else looking for something similar in the future, I ended up using the GeodesicLinesToGIS module as the basis for this. Given a DataFrame called 'start_df' that contains two sets of long/lats i.e. X1, Y1, X2, Y2:
from shapely.geometry import Point, LineString
import pandas as pd
from arcgis.features import GeoAccessor
from geodesiclinestogis.geodesicline2gisfile import GeodesicLine2Gisfile
gtg = GeodesicLine2Gisfile()
def make_geodesic_line(row):
    long_lats = tuple(row)
    cd = gtg.gdlComp(long_lats)
    line = [Point(x) for x in cd]
    line = LineString(line)
    line = str(line)
    return line
lines = start_df.apply(make_geodesic_line, axis = 1)
df = pd.DataFrame({
    'id' : list_of_ids,
    'SHAPE' : lines
sedf = pd.DataFrame().spatial.from_df(df, geometry_column = 'SHAPE')
If you wanted, then it shouldn't be too difficult to take the calculations from the GeodesicLinesToGIS module directly instead of importing it as a dependency.
DanPatterson
MVP Esteemed Contributor
No, but you can roll out your own if you want to use arcpy or even shapely
... sort of retired...
ChadPeltier
Thanks Dan.
import pandas as pd
    line = str(line)
    return line
df = pd.DataFrame({
    'id' : list_of_ids,
    'SHAPE' : lines
