ArcGIS API for Python - FeatureSet.save() Error
2978
7
03-26-2025 11:28 AM
ewmahaffey
I'm trying to use the ArcGIS API for Python without ArcPy. I've written a basic script that connects to a WFS, creates a FeatureLayer, then FeatureSet. I then tried to use the FeatureSet.save() function to simply save the data to a local Shapefile. When I run the script (in the Idle IDE), I get an error saying: "ImportError: ArcPy is required to export a feature class".  From a few other threads that I've read, I should be able to run this without ArcPy. Any thoughts?
from arcgis.features import FeatureLayer
from arcgis.features import FeatureSet
hurricaneDir = r'C:/Workspace/Temp'
PastTracksURL = 'https://services9.arcgis.com/RHVPKKiFTONKtxq3/arcgis/rest/services/Active_Hurricanes_Sampler/FeatureServer/3'
feature_layer = FeatureLayer(PastTracksURL)
feature_set = feature_layer.query(out_fields='*')
feature_set.save(hurricaneDir, "PastTracks_Temp_Data.shp")
print ("WFS Data Successfully Saved as a Shapefile")
Python 3.11.2 (tags/v3.11.2:878ead1, Feb  7 2023, 16:38:35) [MSC v.1934 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license()" for more information.
======= RESTART: C:\Workspace\Temp\WFS_to_FeatureClass_forEsriSupport.py =======
  File "C:\Workspace\Temp\WFS_to_FeatureClass_forEsriSupport.py", line 10, in <module>
  File "C:\Workspace\Python_Virtual_Environment\Lib\site-packages\arcgis\features\feature.py", line 1409, in save
    raise ImportError("ArcPy is required to export a feature class.")
ImportError: ArcPy is required to export a feature class.
Results
ewmahaffey
Although I wasn't able to get the FeatureSet.save() function to work like the API Reference guide said it would.  I kept getting the "ImportError: ArcPy is required to export a feature class" error.  Here's the final script in case anyone needs it.
## the filepath for the output shapefile
hurricane_shp = r'C:/Workspace/Temp/PastTracks_Temp_Data.shp'
## the url to the feature layer
PastTracksURL = 'https://services9.arcgis.com/RHVPKKiFTONKtxq3/arcgis/rest/services/Active_Hurricanes_Sampler/FeatureServer/2'
#PastTracksURL = 'https://services9.arcgis.com/RHVPKKiFTONKtxq3/arcgis/rest/services/Active_Hurricanes_v1/FeatureServer/3'
## create FeatureLayer object
df = feature_layer.query(where = "Shape__Length is not null", out_fields = "*", return_geometry=True).sdf
print (df)
## export to shapefile
df.spatial.to_featureclass(hurricane_shp)
print ("Done")
CodyPatterson
MVP Regular Contributor
Hey @ewmahaffey
You may be able to use geopandas to save as a Shapefile is this here is giving you some issues:
import geopandas as gpd
import json
geojson_str = feature_set.to_geojson
gdf = gpd.read_file(json.dumps(json.loads(geojson_str)))
output_shp = hurricaneDir + '/PastTracks_Temp_Data.shp'
gdf.to_file(output_shp)
# Here you may need to_file like this: to_file(output_shp, driver='ESRI Shapefile')
print("WFS Data Successfully Saved as a Shapefile")
I haven't used this method in quite a long time, you might need to try a couple different conversions out!
Cody
ewmahaffey
Thanks Cody.  I've tried using Pandas GDFs and SDFs but haven't had much luck. One thing I did notice was that this code would work for a WFS that has point data, but not a WFS with polylines
feature_set.sdf.spatial.to_featureclass(PastTracks_Temp_Output, overwrite=True)
I tried running your code sample and got a KeyError
KeyError: 'geometry'
Clubdebambos
Hi @ewmahaffey,
Give this a whirl. While this works for me, it could be that I have access to ArcPy, so it would be interesting to see if it works in your environment,
from arcgis.features import GeoAccessor
## convert to df
df = GeoAccessor.from_layer(feature_layer)
Please let us know.
All the best,
Glen
~ learn.finaldraftmapping.com
ewmahaffey
Thanks Glen. I ran your code in my Python VENV and I'm getting a similar error message that I received when I was testing the use of SDFs and GDFs. It seems like I need to define the geometry type or something.  From I can tell it thinks the geometry is in polygon format even though it's polylines, and no results come back. It's so strange
= RESTART: C:/Workspace/Temp/WFS_to_FeatureClass_forEsriSupport_wGeoAccessor.py
  File "C:/Workspace/Temp/WFS_to_FeatureClass_forEsriSupport_wGeoAccessor.py", line 17, in <module>
  File "C:\Workspace\Python_Virtual_Environment\Lib\site-packages\arcgis\features\geo\_accessor.py", line 2107, in to_featureclass
    result = to_featureclass(
  File "C:\Workspace\Python_Virtual_Environment\Lib\site-packages\arcgis\features\geo\_io\fileops.py", line 1297, in to_featureclass
    res = _pyshp2(df=df, out_path=out_location, out_name=fc_name)
  File "C:\Workspace\Python_Virtual_Environment\Lib\site-packages\arcgis\features\geo\_io\fileops.py", line 1510, in _pyshp2
    if geom.type == "Polygon":
AttributeError: 'NoneType' object has no attribute 'type'
ewmahaffey
OK, so we discovered that the code is actually correct, but the backend service has data integrity errors. Which is unfortunate.  There is a record that does not have a geometry value, that causes errors.
I tested a couple of the other layers coming from this service, and found a similar issue. However, I tested layers from https://services9.arcgis.com/RHVPKKiFTONKtxq3/arcgis/rest/services/Active_Hurricanes_v1/FeatureServe... and it works fine. I hope this helps someone else who might stumble upon this. Maybe the data will get fixed in the "Active_Hurricanes_Sampler" service.  For now I just plan to query out the Null records.
ewmahaffey
print (df)
print ("Done")
RDCOGIS
curious,....now that you are filtering out the bad geometry, can you go back to the .save method, without pandas .sdf
fl = FeatureLayer(_itemUrl)
features = fl.query(where='Shape is not NULL', out_sr=26911)
# save to disk
print('saving the Feature Layer to Shapefile')
features.save(save_location=_pathShps, out_name=_friendlyName + '.shp')
