Adding fields to <class 'arcgis.features.layer.Table'>: TypeError: Object of type PropertyMap is not JSON serializable
200
a week ago
geo_sunriver
Hi Everyone,
I'm following the ArcGIS API for Python docs in attempts to add a long list of fields to a Table.
The code example I'm trying to replicate from the docs is here below:
>>> new_field = {
"fields": [
"name": "Loc Identifier",
"type": "esriFieldTypeString",
"alias": "safa",
"nullable": True,
"editable": True,
"length": 256,
>>> res = fl.manager.add_to_definition(
json_dict=add_field
>>> res
My object of new fields which prints type of <class 'dict'> is shown here below:
fields_to_add = []
for field in source_fields:
        # Check if the field should be ignored or if it already exists
        if field['name'].lower() not in fields_to_ignore_lower and field['name'].lower() not in target_field_names:
        fields_to_add.append(field)
field_dict = {"fields":fields_to_add}
print(field_dict)
{'fields': [{
  "name": "PropID",
  "type": "esriFieldTypeInteger",
  "alias": "PropID",
  "sqlType": "sqlTypeOther",
  "nullable": true,
  "editable": true,
  "domain": null,
  "defaultValue": null
  "name": "SRLaneLot",
  "alias": "SRLaneLot",
  "length": 255,
  "nullable": true,
  "editable": true,
  "domain": null,
}, { ... continues on with the rest of the fields ...
 When I try to use the 'add_to_definition' method I get the following type error:
result = target_table.manager.add_to_definition(field_dict)
print(result)
As I type this out I realise the docs are showing the add_to_definition method for a type of FeatureLayer. Does anyone know how to add fields to a table that exists as a relationship class in ArcGIS Online?
geo_sunriver
The solution was right on front of me...
field_dict_list = []
for f in fields_to_add:
field_dict_list.append(dict(f))
I just needed to convert the type of PropertyMap to a dict, append to a list. Then use the list of dictionaries to update the table.
geo_sunriver
