AddGeometryAttributes_management failing to execute
2911
06-12-2019 11:42 AM
AndrewVanWie
I'm having a problem where I'm trying to calculate area of geometry but it is failing in my Python script. Using ArcGIS 10.6.1.
arcpy.AddGeometryAttributes_management("layername", "AREA", Area_Unit="SQUARE_KILOMETERS")
  File "c:\program files (x86)\arcgis\desktop10.6\ArcToolbox\Scripts\AddGeometryAttributes.py", line 292, in <module>
    AddGeometryAttributes(fc, geomProperties, lUnit, aUnit, cs)
  File "c:\program files (x86)\arcgis\desktop10.6\ArcToolbox\Scripts\AddGeometryAttributes.py", line 49, in AddGeometryAttributes
    fields = CreateOutputFields(fc, geomProperties, hasZ, hasM)
  File "c:\program files (x86)\arcgis\desktop10.6\ArcToolbox\Scripts\AddGeometryAttributes.py", line 232, in CreateOutputFields
    currentFields = [field.name for field in arcpy.ListFields(fc)]
TypeError: 'geoprocessing list object' object is not iterable
Failed to execute (AddGeometryAttributes).
Any ideas?
JoshuaBixby
MVP Esteemed Contributor
sharing with Python‌ since this is an ArcPy question and not ArcGIS API for Python question.  Also, Andrew VanWie‌, please change this to a question instead of a discussion.
RandyBurton
Can you share a bit more of your script - specifically, where the layer name is being set?
AndrewVanWie
Pardon my newbie-ness with Python. Hope this makes sense. Not sure how to change my post from Discussion to Question.
I have 8 workstations and users running ArcGIS 10.6. I get the error on only 2 workstations, it works well on the other 6, so that is my confusion. The workstations should be set up identically.
After selecting a feature from the "blocks" layer in ArcMap, I run an executable script in the ArcMap Python window that requires parameters for "blockname" and "point density" to scatter random points in polygons at specified density:
import sys
sys.argv = ["path_to_script.py", "NXXWXXX", "####"]
execfile( "path_to_script.py" )
Then, in my main script "path_to_script.py" I set the layername with sys.argv[1] and sys.argv[2]. Processing is done from source data paths for imagery and features, running arcpy scripts. All layer processing is output to a temporary geodatabase workspace, which is removed at the end. I removed the remaining processing arcpy lines following arcpy.AddGeometryAttributes_management for sake of space since this is where it fails. Everything works right up to it.
import arcpy
import tempfile
def main ( ):
   blockname = sys.argv[1]
   point_density = sys.argv[2]
   arcpy.CreateFileGDB_management(tempfile.gettempdir(), blockname + "_" + point_density)
   arcpy.CreateFeatureDataset_management(tempfile.gettempdir() + "/" + blockname + "_" + point_density + ".gdb", "dataset1", "WGS 1984 UTM Zone 17N.prj")
   arcpy.env.workspace = tempfile.gettempdir() + "/" + blockname + "_" + point_density + ".gdb"
   try:
    arcpy.MakeFeatureLayer_management ("blocks", blockname + "_Layer")
    arcpy.Clip_management(polygon_features_path, "#", blockname + "_clip", blockname + "_Layer", "#", "ClippingGeometry")
    arcpy.Clip_analysis(feature_buffers_path, blockname + "_Layer", blockname + "_buffers")
    arcpy.RasterToPolygon_conversion(blockname + "_clip", "dataset1/" + blockname + "_rast2poly", "NO_SIMPLIFY")
    qry = '"gridcode" > 35'
    flayer = arcpy.MakeFeatureLayer_management (blockname + "_rast2poly", blockname + "_rast2poly2_Layer")
    arcpy.SelectLayerByAttribute_management (flayer, "NEW_SELECTION", qry)
    arcpy.CopyFeatures_management (flayer, "dataset1/" + blockname + "_export")
    arcpy.Dissolve_management (blockname + "_export", "dataset1/" + blockname + "_dissolve")
    arcpy.AddGeometryAttributes_management(blockname + "_dissolve", "AREA", Area_Unit="SQUARE_KILOMETERS")
if __name__ == '__main__':
   main()
RandyBurton
With only a quick look, I see you are sometimes using "dataset1/" + ... and sometimes not using it.  I wonder if the inconsistency is the issue.  You might try:
arcpy.Dissolve_management ("dataset1/" + blockname + "_export", "dataset1/" + blockname + "_dissolve")
arcpy.AddGeometryAttributes_management("dataset1/" + blockname + "_dissolve", "AREA", Area_Unit="SQUARE_KILOMETERS")‍‍‍‍
AndrewVanWie
Upgrading to ArcGIS Desktop 10.7.1 somehow fixed the issue on the 2 workstations that were affected. I'm not sure what was going on with 10.6.
