While going through the following Url: https://developers.arcgis.com/javascript/jssamples/widget_directions_basic.html I found that when I view Live Sample, it is working fine. But when I implement the Sample Code on my local machine or Download the zip
4598
12-11-2015 05:00 AM
AlokDwivedi1
But when I implement the Sample Code on my local machine or Download the zip file and then implement, it shows unable to route addresses.
Pic2
Also when I add the
routeTaskUrl: "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Route"
still it shows the same error.
Please suggest and help.
thejuskambi
Occasional Contributor III
Have you setup the proxy as mentioned in that sample?
AlokDwivedi1
Hi, Thanks for looking into the issue.
I have used the same code mentioned in the sample. Could you please check it.
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="ArcGISDirections.aspx.cs" Inherits="ESRI.ArcGISDirections" %>
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Directions Widget</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
    </style>
    <script src="https://js.arcgis.com/3.15/"></script>
    <script>
      require([
        "esri/urlUtils", "esri/map", "esri/dijit/Directions",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        urlUtils, Map, Directions,
        parser
        parser.parse();
        //all requests to route.arcgis.com will proxy to the proxyUrl defined in this object.
        urlUtils.addProxyRule({
          urlPrefix: "route.arcgis.com",
          proxyUrl: "/sproxy/"
          urlPrefix: "traffic.arcgis.com",
        var map = new Map("map", {
          basemap: "streets",
          center:[-98.56,39.82],
          zoom: 4
        //travelModesServiceUrl option points to logistics service hosted from ArcGIS Online
        //by indicating this URL, a login prompt should not display
        var directions = new Directions({
            map: map,
            routeTaskUrl: "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Route",
          travelModesServiceUrl: "http://utility.arcgis.com/usrsvcs/servers/cdc3efd03ddd4721b99adce219629489/rest/services/World/Utili..."
        },"dir");
        directions.startup();
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'right'"
           style="width:250px;">
        <div id="dir"></div>
      </div>
      <div id="map"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
thejuskambi
Hello Alok,
The code is not the problem, you need a proxy service/application setup in order to process request.  Check this out, it will give information about proxy and how to set it up.
Using the proxy | Guide | ArcGIS API for JavaScript
Hope this was helpful.
Thejus
