While going through the following Url: https://developers.arcgis.com/javascript/jssamples/widget_directions_basic.html I found that when I view Live Sample, it is working fine. But when I implement the Sample Code on my local machine or Download the zip
6307
12-11-2015 05:00 AM
AlokDwivedi1
But when I implement the Sample Code on my local machine or Download the zip file and then implement, it shows unable to route addresses.
Pic2
Also when I add the
routeTaskUrl: "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Route"
still it shows the same error.
Please suggest and help.
thejuskambi
Have you setup the proxy as mentioned in that sample?
AlokDwivedi1
Hi, Thanks for looking into the issue.
I have used the same code mentioned in the sample. Could you please check it.
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="ArcGISDirections.aspx.cs" Inherits="ESRI.ArcGISDirections" %>
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Directions Widget</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
    </style>
    <script src="https://js.arcgis.com/3.15/"></script>
    <script>
      require([
        "esri/urlUtils", "esri/map", "esri/dijit/Directions",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        urlUtils, Map, Directions,
        parser
        parser.parse();
        //all requests to route.arcgis.com will proxy to the proxyUrl defined in this object.
        urlUtils.addProxyRule({
          urlPrefix: "route.arcgis.com",
          proxyUrl: "/sproxy/"
          urlPrefix: "traffic.arcgis.com",
        var map = new Map("map", {
          basemap: "streets",
          center:[-98.56,39.82],
          zoom: 4
        //travelModesServiceUrl option points to logistics service hosted from ArcGIS Online
        //by indicating this URL, a login prompt should not display
        var directions = new Directions({
            map: map,
            routeTaskUrl: "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Route",
          travelModesServiceUrl: "http://utility.arcgis.com/usrsvcs/servers/cdc3efd03ddd4721b99adce219629489/rest/services/World/Utili..."
        },"dir");
        directions.startup();
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'right'"
           style="width:250px;">
        <div id="dir"></div>
      </div>
      <div id="map"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
thejuskambi
Hello Alok,
The code is not the problem, you need a proxy service/application setup in order to process request.  Check this out, it will give information about proxy and how to set it up.
Using the proxy | Guide | ArcGIS API for JavaScript
Hope this was helpful.
Thejus
