Please forgive me for what is probably a totally newbie question, but the programmer who started this project left and I am really under the gun. I have looked at every sample I could find, and have searched the forum to no avail.
We are able to pull up all of the properties within a (user-defined) radius of the center of our subject property.
What I need to do is to place text near the center of each of the properties that fall within the radius. (HCAD_NUM, Site Address, etc. from the ShapeFile)
I see how to get the extents for the map, but how to determine the location and size of the individual plots escapes me.
I would also like to determine the width of the individual plots so I can adjust the fonts size and, perhaps text rotation so the text doesn't leak over onto other properties. (Desired Text is shown in red)
My failed attempt to add text is at the very bottom.
require([ "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/tasks/QueryTask", "esri/tasks/query", "dojo/dom", "dojo/on", "esri/layers/FeatureLayer", "esri/Color", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer", "esri/geometry/Extent", "dojo/parser", "esri/geometry/Circle", "esri/units", "esri/symbols/Font", "esri/symbols/TextSymbol", "esri/layers/LabelClass", "esri/config", "esri/graphic", "esri/tasks/GeometryService", "esri/tasks/BufferParameters", "esri/toolbars/draw", "esri/symbols/SimpleMarkerSymbol", "dojo/domReady!"], function (Map, ArcGISDynamicMapServiceLayer, QueryTask, Query, dom, on, FeatureLayer, Color, SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer, Extent, parser, Circle, Units, Font, TextSymbol) { parser.parse(); //map = new Map("map"); map = new Map("map", { //extent: bbox, showLabels: true //very important that this must be set to true! }); var baseLayer = new ArcGISDynamicMapServiceLayer("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); map.addLayer(baseLayer); var countyLayer = new FeatureLayer("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); var outline = new SimpleLineSymbol("solid", new Color([255, 255, 255, 1]), 2); var fill = new SimpleFillSymbol("solid", outline, new Color([255, 255, 0, 0.5])); countyLayer.setRenderer(new SimpleRenderer(fill)); map.addLayer(countyLayer); //Query the parcels layer for the subject property queryTask = new QueryTask("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); query = new Query(); query.returnGeometry = true; query.outFields = ["HCAD_NUM", "LocAddr"]; //Set up a callback for when the get details button is pressed. function execute() { query.where = "HCAD_NUM = '" + dom.byId("hcad_num").value + "'"; queryTask.execute(query, foundSubject); } on(dom.byId("execute"), "click", execute); //Set up a query for function foundSubject(results) { var f = results.features; //new Circle(center, options?) https://developers.arcgis.com/javascript/jsapi/circle-amd.html circle = new Circle({ center: f[0].geometry.getExtent().getCenter(), radius: dom.byId("distance").value, radiusUnit: Units.FEET }); //Execute a new query that searches for all properties around subject var areaQuery = new Query(); areaQuery.geometry = circle.getExtent(); areaQuery.returnGeometry = true; areaQuery.outFields = ["HCAD_NUM", "LocAddr"]; queryTask.execute(areaQuery, showResults); } function showResults(results) { var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 1.0), new Color([180, 180, 180, 1]) ); map.graphics.clear(); var resultFeatures = results.features; //Zoom to parcel var ex = esri.graphicsExtent(resultFeatures); map.setExtent(ex); for (var i = 0, il = resultFeatures.length; i < il; i++) { var graphic = resultFeatures; graphic.setSymbol(symbol); var featureAttributes = graphic.attributes; var resultItems = []; for (var attr in featureAttributes) { resultItems.push("<b>" + attr + ":</b> " + featureAttributes[attr] + "<br>"); } resultItems.push("<br>"); map.graphics.add(graphic); var textSymbol = new TextSymbol(featureAttributes[attr]); map.graphics.add(textSymbol); } dom.byId("info").innerHTML = resultItems.join(""); } });
Allen,
Maybe this will get you started:
<!DOCTYPE html> <html> <head> <meta charset="utf-8" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <link rel="stylesheet" href="https://js.arcgis.com/3.14/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css"> <script src="https://js.arcgis.com/3.15/"></script> <script> //Avoids cross site scripting warnings require(["esri/config"], function (esriConfig) { esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:8080"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:80"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:443"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:6080"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:6443"); }); var map; require([ "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/tasks/QueryTask", "esri/tasks/query", "dojo/dom", "dojo/on", "esri/layers/FeatureLayer", "esri/Color", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer", "esri/geometry/Extent", "dojo/parser", "esri/geometry/Circle", "esri/units", "esri/symbols/Font", "esri/symbols/TextSymbol", "esri/config", "esri/tasks/GeometryService", "esri/tasks/BufferParameters", "esri/toolbars/draw", "esri/symbols/SimpleMarkerSymbol", "esri/graphic", "esri/geometry/Point", "esri/layers/LabelClass", "dijit/layout/ContentPane", "dojo/domReady!"], function (Map, ArcGISDynamicMapServiceLayer, QueryTask, Query, dom, on, FeatureLayer, Color, SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer, Extent, parser, Circle, Units, Font, TextSymbol, esriConfig, GeometryService, BufferParameters, Draw, SimpleMarkerSymbol, Graphic, Point, LabelClass) { parser.parse(); map = new Map("mapDiv", { showLabels: true }); var baseLayer = new ArcGISDynamicMapServiceLayer("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); map.addLayer(baseLayer); var countyLayer = new FeatureLayer("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); var outline = new SimpleLineSymbol("solid", new Color([255, 255, 255, 1]), 2); var fill = new SimpleFillSymbol("solid", outline, new Color([255, 255, 0, 0.5])); countyLayer.setRenderer(new SimpleRenderer(fill)); map.addLayer(countyLayer); //Query the parcels layer for the subject property queryTask = new QueryTask("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); query = new Query(); query.returnGeometry = true; query.outFields = ["HCAD_NUM", "LocAddr"]; //Set up a callback for when the get details button is pressed. function execute() { query.where = "HCAD_NUM = '" + dom.byId("hcad_num").value + "'"; queryTask.execute(query, foundSubject); } on(dom.byId("execute"), "click", execute); //Set up a query for function foundSubject(results) { var f = results.features; //new Circle(center, options?) https://developers.arcgis.com/javascript/jsapi/circle-amd.html circle = new Circle({ center: f[0].geometry.getExtent().getCenter(), radius: dom.byId("distance").value, radiusUnit: Units.FEET }); //Execute a new query that searches for all properties around subject var areaQuery = new Query(); areaQuery.geometry = circle.getExtent(); areaQuery.returnGeometry = true; areaQuery.outFields = ["HCAD_NUM", "LocAddr"]; queryTask.execute(areaQuery, showResults); } function showResults(results) { var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 1.0), new Color([180, 180, 180, 1]) ); map.graphics.clear(); var resultFeatures = results.features; //Zoom to parcel var ex = esri.graphicsExtent(resultFeatures); map.setExtent(ex); var font = new Font(); font.setSize("7pt"); font.setWeight(Font.WEIGHT_BOLD); var Textcolor = new Color(); Textcolor.setColor([255, 0, 0]); for (var i = 0, il = resultFeatures.length; i < il; i++) { var graphic = resultFeatures; var ext = graphic.geometry.getExtent(); //var gWidth = ext.getWidth(); //var gHeight = ext.getHeight(); var gCenter = ext.getCenter(); var AcctText = new TextSymbol(); AcctText.setFont(font); AcctText.setColor(Textcolor); AcctText.setText(graphic.attributes.HCAD_NUM); graphic.setSymbol(symbol); var gra = new Graphic(gCenter,AcctText) var featureAttributes = graphic.attributes; var resultItems = []; for (var attr in featureAttributes) { resultItems.push("<b>" + attr + ":</b> " + featureAttributes[attr] + "<br>"); } resultItems.push("<br>"); map.graphics.add(graphic); map.graphics.add(gra); } dom.byId("info").innerHTML = resultItems.join(""); } }); </script> <title>CTN GIS</title> <style type="text/css"> #distance { width: 75px; } #mapDiv { padding: 0; margin: 0; height: 100%; width: 100%; overflow: hidden; } </style> </head> <body class="tundra"> Account: <input type="text" id="hcad_num" value="1122030000018" /> Radius: <input type="text" id="distance" value="500" /> <input id="execute" type="button" value="Show Map" /> <br /> <br /> <div id="info" style="padding:5px; margin:5px; background-color:#eee;"></div> <br /> <br /> <div id="mapDiv"></div> </body> </html>
Allen,
Sounds like that you are looking for is the extent of the graphic you want to label. Using the extent would give you the centerpoint to label on and the width and height of the bounding extent of the graphic.
So in your for loop of the results you would do
var ext = graphic.geometry.getExtent(); var gWidth = ext.getWidth(); var gHeight = ext.getHeight(); var gCenter = ext.getCenter();
Thanks, Robert.
I am sorry I took so long. I have been wrestling with this thing since you wrote, and was hoping to have an intelligent reply... But no luck.
This has been a very humbling experience to say the least.
I was able to use your suggestion without error, and was able to place "Hello World" all around the map, but I can't get the parcel outlines and labels to show up at the same time.
Still wrestling.
Allen,
Can you provide your full html file for me to go over?
It is an aspx page, but should run as a simple HTML
Thank you so much! The county doesn't provide labels in the Shape File, so I have to "wing it" on the text.
I am hoping to include the HCAD_NUM from the query instead of "Hello, world" as the text, but haven't had any luck with that, either.
P.S. if you comment out the "graphic.setSymbol(AcctText);" you can see the outlines of the parcels.
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="map.aspx.vb" Inherits="map" %> <!DOCTYPE html> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta charset="utf-8" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <link href="Styles/Tundra.css" rel="stylesheet" /> <link href="Styles/ESRI.css" rel="stylesheet" /> <script src="https://js.arcgis.com/3.15/"></script> <script> //Avoids cross site scripting warnings require(["esri/config"], function (esriConfig) { esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:8080"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:80"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:443"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:6080"); esriConfig.defaults.io.corsEnabledServers.push("arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com:6443"); }); require([ "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/tasks/QueryTask", "esri/tasks/query", "dojo/dom", "dojo/on", "esri/layers/FeatureLayer", "esri/Color", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer", "esri/geometry/Extent", "dojo/parser", "esri/geometry/Circle", "esri/units", "esri/symbols/Font", "esri/symbols/TextSymbol", "esri/config", "esri/tasks/GeometryService", "esri/tasks/BufferParameters", "esri/toolbars/draw", "esri/symbols/SimpleMarkerSymbol", "esri/graphic", "esri/geometry/Point", "esri/layers/LabelClass", "dojo/domReady!"], function (Map, ArcGISDynamicMapServiceLayer, QueryTask, Query, dom, on, FeatureLayer, Color, SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer, Extent, parser, Circle, Units, Font, TextSymbol, Graphic, Point, LabelClass) { parser.parse(); map = new Map("map", { showLabels: true }); var baseLayer = new ArcGISDynamicMapServiceLayer("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); map.addLayer(baseLayer); var countyLayer = new FeatureLayer("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); var outline = new SimpleLineSymbol("solid", new Color([255, 255, 255, 1]), 2); var fill = new SimpleFillSymbol("solid", outline, new Color([255, 255, 0, 0.5])); countyLayer.setRenderer(new SimpleRenderer(fill)); map.addLayer(countyLayer); //Query the parcels layer for the subject property queryTask = new QueryTask("https://arcgis-ctngis-1263207624.us-west-2.elb.amazonaws.com/arcgis/rest/services/HCAD/CADDataAndPar..."); query = new Query(); query.returnGeometry = true; query.outFields = ["HCAD_NUM", "LocAddr"]; //Set up a callback for when the get details button is pressed. function execute() { query.where = "HCAD_NUM = '" + dom.byId("hcad_num").value + "'"; queryTask.execute(query, foundSubject); } on(dom.byId("execute"), "click", execute); //Set up a query for function foundSubject(results) { var f = results.features; //new Circle(center, options?) https://developers.arcgis.com/javascript/jsapi/circle-amd.html circle = new Circle({ center: f[0].geometry.getExtent().getCenter(), radius: dom.byId("distance").value, radiusUnit: Units.FEET }); //Execute a new query that searches for all properties around subject var areaQuery = new Query(); areaQuery.geometry = circle.getExtent(); areaQuery.returnGeometry = true; areaQuery.outFields = ["HCAD_NUM", "LocAddr"]; queryTask.execute(areaQuery, showResults); } function showResults(results) { var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 1.0), new Color([180, 180, 180, 1]) ); map.graphics.clear(); var resultFeatures = results.features; //Zoom to parcel var ex = esri.graphicsExtent(resultFeatures); map.setExtent(ex); var font = new Font(); font.setSize("7pt"); font.setWeight(Font.WEIGHT_BOLD); var Textcolor = new Color(); Textcolor.setColor([255, 0, 0]); for (var i = 0, il = resultFeatures.length; i < il; i++) { var graphic = resultFeatures; //var ext = graphic.geometry.getExtent(); //var gWidth = ext.getWidth(); //var gHeight = ext.getHeight(); //var gCenter = ext.getCenter(); var AcctText = new TextSymbol(); AcctText.setFont(font); AcctText.setColor(Textcolor); AcctText.setText("Hello, World"); graphic.setSymbol(symbol); graphic.setSymbol(AcctText); var featureAttributes = graphic.attributes; var resultItems = []; for (var attr in featureAttributes) { resultItems.push("<b>" + attr + ":</b> " + featureAttributes[attr] + "<br>"); } resultItems.push("<br>"); map.graphics.add(graphic); } dom.byId("info").innerHTML = resultItems.join(""); } }); </script> <title>CTN GIS</title> <style type="text/css"> #distance { width: 75px; } </style> </head> <body class="tundra"> Account: <input type="text" id="hcad_num" value="1122030000018" /> Radius: <input type="text" id="distance" value="500" /> <input id="execute" type="button" value="Show Map" /> <br /> <br /> <div id="info" style="padding:5px; margin:5px; background-color:#eee;"> </div> <br /><br /> <div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="padding:0;"> </div> </div> <br /><br /> </body> </html>
Allen,
You are a genius! I've been wrestling with this off and on since I sent it. Featurelayers, on and on... Thanks a million!
Allen,
You are welcome. Don't forget to mark this question as answered.
