Selected rows in a FeatureTable
2515
11-12-2020 02:29 PM
KenBuja
MVP Esteemed Contributor
There doesn't seem to be a way of getting the selected rows easily from a FeatureTable (v 4.17). The 3.x version has the selectedRows property...am I missing something? Currently, I am using the selection-change event to write the added and removed property arrays to a separate array
    featureTable.on('selection-change', (event) => {
      if (event.added.length > 0) filterArray.push(event.added[0].feature.attributes[valueString]);
      if (event.removed.length === 1) {
        const i = filterArray.indexOf(event.removed[0].feature.attributes[valueString]);
        filterArray.splice(i, 1);
      } else if (event.removed.length > 0) {
        filterArray = [];
Tags (1)
KavishGhime3
Hello @KenBuja
In the 4.x API reference, I cannot see the equivalent property of "selectedRows" which returns the name-value pair object in 3.x API.
In API 4.x, FeatureTable is still in Beta and new capabilities will be added in upcoming releases. For a more comprehensive list of limitations, please refer to the widget's API Reference documentation.
MichaelKarikari1
I still don't see selectedRows as API option. Is it safe to say it is still not available yet and the poster except is the best option for now?
ZachPorteous
That would be a great feature!!
MichaelCollinsGIS
I had wondered about this as well, and it seems the accepted way to do it is to instantiate a global variable, then modify it using the data from the change event. This works fine (albeit a little clumsy), and there is a good example of it here: Sandbox | Sample Code | ArcGIS API for JavaScript 4.24 | ArcGIS Developers
