Thank You Miriam,
I have tried the code but its not working. Check help. I want to select the graphic and the delete it through button click and not by right clicking on the graphic.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<title>Create a Map</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<style>
html,
body,
#mapDiv {
padding: 0;
margin: 0;
height: 100%;
button {
display: block;
</style>
<script src="http://js.arcgis.com/3.10/"></script>
<script>
var map, tb, ctxMenuForGraphics;
require([
"esri/map", "esri/toolbars/draw", "esri/geometry/Point", "esri/geometry/Polygon", "esri/toolbars/edit",
"esri/geometry/jsonUtils", "dijit/Menu", "dijit/MenuItem", "dijit/MenuSeparator",
"esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
"esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol",
"esri/graphic", "esri/Color", "dojo/dom", "dojo/on", "dojo/parser",
"dijit/form/Button", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/form/ComboBox",
"dijit/layout/TabContainer", "dijit/form/NumberSpinner", "dijit/form/TextBox", "dijit/ColorPalette",
"dojo/domReady!"
], function (
Map, Draw, Point, Polygon,
Edit, geometryJsonUtils, Menu, MenuItem, MenuSeparator,
SimpleMarkerSymbol, SimpleLineSymbol,
PictureFillSymbol, CartographicLineSymbol,
Graphic,
Color, dom, on, parser
parser.parse();
map = new Map("mapDiv", {
basemap: "streets",
center: [-25.312, 34.307],
zoom: 3
map.on("load", initToolbar);
createGraphicsMenu();
ctxMenuForMap.startup();
ctxMenuForMap.bindDomNode(map.container);
//map.on("resize", resizeMap);
function initToolbar() {
tb = new Draw(map);
tb.on("draw-end", addToMap);
// event delegation so a click handler is not
// needed for each individual button
on(dom.byId("info"), "click", function (evt) {
if (evt.target.id === "info") {
return;
var tool = evt.target.id.toLowerCase();
if (tool == "clear") {
map.graphics.clear();
map.enableMapNavigation();
} else {
//map.disableMapNavigation();
tb.activate(tool);
function addToMap(evt) {
//deactivate the toolbar and clear existing graphics
tb.deactivate();
var font = new esri.symbol.Font();
font.setSize(parseInt(dojo.byId("tsSize").value));
font.setFamily(parseInt(dojo.byId("tsWeight").value));
var symbol = new esri.symbol.TextSymbol();
symbol.setText(dojo.byId("tsText").value);
symbol.setColor(new dojo.Color(dijit.byId("tsColor").value));
symbol.setFont(font);
symbol.setAngle(parseInt(dojo.byId("tsAngle").value));
map.graphics.add(new Graphic(evt.geometry, symbol));
function createGraphicsMenu() {
// Creates right-click context menu for GRAPHICS
ctxMenuForGraphics = new Menu({});
ctxMenuForGraphics.addChild(new MenuSeparator());
ctxMenuForGraphics.addChild(new MenuItem({
label: "Delete",
onClick: function () {
map.graphics.remove(selected);
ctxMenuForGraphics.startup();
map.graphics.on("mouse-over", function (evt) {
// We'll use this "selected" graphic to enable editing tools
// on this graphic when the user click on one of the tools
// listed in the menu.
selected = evt.graphic;
// Let's bind to the graphic underneath the mouse cursor
ctxMenuForGraphics.bindDomNode(evt.graphic.getDojoShape().getNode());
map.graphics.on("mouse-out", function (evt) {
ctxMenuForGraphics.unBindDomNode(evt.graphic.getDojoShape().getNode());
</script>
</head>
<body class="claro">
<div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="sidebar" gutters="false" style="width:100%; height:100%;">
<div id="mapDiv" dojotype="dijit.layout.ContentPane" region="center" style="margin:5px;">
</div>
<div dojotype="dijit.layout.TabContainer" region="right" style="width:25%;margin:5px;">
<div dojotype="dijit.layout.ContentPane" selected="true" title="Symbol Properties">
<br />
Enter Text:
<input dojotype="dijit.form.TextBox" value="Text" id="tsText" />
<br />
<br />Color :
<br />
<div id="colorButton" style="background-color: #FFFFFF; border-color: black; border-width: 1px;" dojotype="dijit/form/DropDownButton">
<span id="colorText"> <span id="colorSwatch" style="height: 10px; width: 10px; border: 1px solid black; background-color: black;"> </span></span>
<div data-dojo-type="dijit/TooltipDialog" id="colorPaletteDialog" title="Color Palette">
<div data-dojo-type="dijit/ColorPalette" id="tsColor"></div>
</div>
</div>
<br />
<br />
<br />Angle :
<br />
<input dojotype="dijit.form.NumberSpinner" value="0" constraints="{min:-360,max:360}" id="tsAngle" />
<br>Font:
<br />
<select id="tsWeight" dojotype="dijit.form.ComboBox" autocomplete="false" value="WEIGHT_NORMAL">
<option value="Arial">Arial</option>
<option value="Times New Roman" selected>Times New Roman</option>
<option value="Garamond">Garamond</option>
</select>
<br />Size :
<br />
<select id="tsSize" dojotype="dijit.form.ComboBox" autocomplete="false" value="14pt">
<option>10pt</option>
<option>12pt</option>
<option selected="selected">14pt</option>
<option>16pt</option>
<option>18pt</option>
<option>20pt</option>
<option>22pt</option>
<option>24pt</option>
<option>26pt</option>
<option>28pt</option>
<option>30pt</option>
</select>
<br /><br />
<div id="info">
<button id="Point" class="btn-blue" style="margin-left:90px;">Text</button><br />
<button id="Clear" class="btn-blue" style="margin-left:60px;">Clear Graphics</button>
<br /><br />
<button onclick="myFunction()">Click me</button>
</div>
</div>
</div>
</div>
</body>
</html>
Regards,
Aditi
