select a text graphics (annotation)on map and delete it arcgis javascript
6543
12
02-29-2016 10:34 PM
ADITIROY
I have graphics on the map and i just want to delete the selected text graphics on button click. Please suggest how to do this.
Thanks for help.
Regards,
Aditi
Tags (3)
MiriamBrockmann
Hi Aditi!
No, it wont do when you copy the code one to one. There are two possible ways :
1. You can highlight the Points, where the Text is anchord or
2. change the Textcolor by looping through the selected Geometries and change the Textcolor.
Regards
ADITIROY
Thank you Miriam,
But is there any code which can be integrated to this code below to make selection work instead on button click, it will work by drawing rectangle on  the text graphic and highlighting the selected text.
on(dom.byId("select"), "click", function () {
                that.map.graphics.on("click", function (evt) {
                    that.selected = evt.graphic;
Thank you again.
MiriamBrockmann
There's no code i can offer you, which you can copy and paste.
I would suggest you write a Shedule what you want to program, what should happend when in which Order, which tools you need for and then write your code.
Above is all you need to do what you want.
