Hi all,
I am trying to use Print template showAttribution option but cant make it work for some reasons. I dont want to show the map sources because it gets cut off sometimes when printing. Any idea?
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title></title>
<link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; }
.shadow {
-moz-box-shadow: 0 0 5px #888;
-webkit-box-shadow: 0 0 5px #888;
#map{ margin: 0; padding: 0; }
#feedback {
background: #fff;
border: 2px solid #666;
border-radius: 5px;
bottom: 20px;
color: #666;
font-family: arial;
height: auto;
left: 20px;
margin: 5px;
padding: 10px;
position: absolute;
width: 300px;
z-index: 40;
#feedback a {
border-bottom: 1px solid #888;
color: #666;
text-decoration: none;
#feedback a:hover, #feedback a:active, #feedback a:visited {
border: none;
color: #666;
#note { padding: 0 0 10px 0; }
#info { padding: 10px 0 0 0; }
</style>
<script src="https://js.arcgis.com/3.16/"></script>
<script>
var app = {};
require([
"esri/arcgis/utils", "esri/dijit/Print",
"esri/tasks/PrintTemplate", "esri/config",
"dojo/_base/array", "dojo/dom", "dojo/parser",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
], function(
arcgisUtils, Print,
PrintTemplate, esriConfig,
arrayUtils, dom, parser
parser.parse();
app.webmapId = "8315cf7d20f0484e869c4791f70f4f15";
app.printUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%...";
esriConfig.defaults.io.proxyUrl = "/proxy/";
var webmap = arcgisUtils.createMap(app.webmapId, "map", {
mapOptions: {
center: [-85.673, 38.21],
zoom: 10
webmap.then(function(resp) {
app.mapInfo = resp.itemInfo.item;
app.map = resp.map;
createPrintDijit(app.mapInfo.title);
function createPrintDijit(printTitle) {
var layoutTemplate, templateNames, mapOnlyIndex, templates;
// create an array of objects that will be used to create print templates
var layouts = [{
name: "Letter ANSI A Landscape",
label: "Landscape (PDF)",
format: "pdf",
options: {
legendLayers: [], // empty array means no legend
scalebarUnit: "Miles",
titleText: printTitle + ", Landscape PDF"
name: "Letter ANSI A Portrait",
label: "Portrait (Image)",
format: "jpg",
options: {
legendLayers: [],
titleText: printTitle + ", Portrait JPG"
// create the print templates
var templates = arrayUtils.map(layouts, function(lo) {
var t = new PrintTemplate();
t.layout = lo.name;
t.showAttribution = false;
t.label = lo.label;
t.format = lo.format;
t.layoutOptions = lo.options;
return t;
app.printer = new Print({
map: app.map,
templates: templates,
url: app.printUrl
}, dom.byId("print_button"));
app.printer.startup();
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="map"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'">
<div id="feedback">
<h3>
ArcGIS.com Webmap and the Print Dijit
</h3>
<div id="info">
<div id="note">
Note: This sample uses an ArcGIS Server version 10.1 export web map task.
</div>
<div id="print_button"></div>
<div id="info">
The map is <a href="https://developers.arcgis.com/javascript/jsapi/esri.arcgis.utils-amd.html#createmap">created from an ArcGIS.com webmap</a> and
<a href="https://developers.arcgis.com/javascript/jsapi/printtemplate-amd.html">print templates</a> are
created manually. Refer to the documentation for more print template options (output formats, additional layouts, etc.).
</div>
</div>
</div>
</div>
</div>
</body>
</html>
