Hi all,
I am trying to use Print template showAttribution option but cant make it work for some reasons. I dont want to show the map sources because it gets cut off sometimes when printing. Any idea?
<!DOCTYPE html> <html> <head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title></title> <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; } .shadow { -moz-box-shadow: 0 0 5px #888; -webkit-box-shadow: 0 0 5px #888; box-shadow: 0 0 5px #888; } #map{ margin: 0; padding: 0; } #feedback { background: #fff; border: 2px solid #666; border-radius: 5px; bottom: 20px; color: #666; font-family: arial; height: auto; left: 20px; margin: 5px; padding: 10px; position: absolute; width: 300px; z-index: 40; } #feedback a { border-bottom: 1px solid #888; color: #666; text-decoration: none; } #feedback a:hover, #feedback a:active, #feedback a:visited { border: none; color: #666; text-decoration: none; } #note { padding: 0 0 10px 0; } #info { padding: 10px 0 0 0; } </style> <script src="https://js.arcgis.com/3.16/"></script> <script> var app = {}; require([ "esri/arcgis/utils", "esri/dijit/Print", "esri/tasks/PrintTemplate", "esri/config", "dojo/_base/array", "dojo/dom", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( arcgisUtils, Print, PrintTemplate, esriConfig, arrayUtils, dom, parser ) { parser.parse(); app.webmapId = "8315cf7d20f0484e869c4791f70f4f15"; app.printUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%..."; esriConfig.defaults.io.proxyUrl = "/proxy/"; var webmap = arcgisUtils.createMap(app.webmapId, "map", { mapOptions: { center: [-85.673, 38.21], zoom: 10 } }); webmap.then(function(resp) { app.mapInfo = resp.itemInfo.item; app.map = resp.map; createPrintDijit(app.mapInfo.title); }); function createPrintDijit(printTitle) { var layoutTemplate, templateNames, mapOnlyIndex, templates; // create an array of objects that will be used to create print templates var layouts = [{ name: "Letter ANSI A Landscape", label: "Landscape (PDF)", format: "pdf", options: { legendLayers: [], // empty array means no legend scalebarUnit: "Miles", titleText: printTitle + ", Landscape PDF" } }, { name: "Letter ANSI A Portrait", label: "Portrait (Image)", format: "jpg", options: { legendLayers: [], scalebarUnit: "Miles", titleText: printTitle + ", Portrait JPG" } }]; // create the print templates var templates = arrayUtils.map(layouts, function(lo) { var t = new PrintTemplate(); t.layout = lo.name; t.showAttribution = false; t.label = lo.label; t.format = lo.format; t.layoutOptions = lo.options; return t; }); app.printer = new Print({ map: app.map, templates: templates, url: app.printUrl }, dom.byId("print_button")); app.printer.startup(); } }); </script> </head> <body class="tundra"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> <div id="feedback"> <h3> ArcGIS.com Webmap and the Print Dijit </h3> <div id="info"> <div id="note"> Note: This sample uses an ArcGIS Server version 10.1 export web map task. </div> <div id="print_button"></div> <div id="info"> The map is <a href="https://developers.arcgis.com/javascript/jsapi/esri.arcgis.utils-amd.html#createmap">created from an ArcGIS.com webmap</a> and <a href="https://developers.arcgis.com/javascript/jsapi/printtemplate-amd.html">print templates</a> are created manually. Refer to the documentation for more print template options (output formats, additional layouts, etc.). </div> </div> </div> </div> </div> </body> </html>
Hi Alex,
I tested this from my side and the issue I believe is that Server REST endpoint doesn't honor this parameter: showAttribution that generates from JavaScript API side.
Checked the REST API online documentation ArcGIS REST API, but I didn't find any reference point to showAttribution, But when you take a look about the request, you can see WebJSON contains "showAttribution"
"mapOptions": { "showAttribution": false,
I have already logged an enhancement for the ArcGIS Server [ENH-000095722 showAttribution value doesn't honor in Export Web Map Task in REST]
Hi Alex,
Interesting! Thank you for sharing.
What I have done is to remove the dynamic element for map attribution in the layouts for the print task when I setup my own custom print service:
Tutorial: Publishing additional services for printing—Documentation | ArcGIS for Server
Supporting High-Quality Printing in Web Applications with ArcGIS 10.1 for Server | Esri Video
Also see this post https://community.esri.com/message/721690 for more information on this topic.
