Hi everyone,
I am new at javascript and developing with the Javascript API.
I wanted to add my TimeSlider into a Expand Widget, I successfully did it (I guess) but since my TimeSlider is inside the expand is not working well, so maybe I am missing something or made some mistake. I hope you could help me with this matter.
Thank you so much for your time and your attention.
Excuse me for my broke englsih.
Here is the code:
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>
Filter features with TimeSlider | Sample | ArcGIS API for JavaScript 4.17
</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.17/esri/themes/dark/main.css"
<script src="https://js.arcgis.com/4.17/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/GeoJSONLayer",
"esri/widgets/Expand",
"esri/widgets/TimeSlider",
"esri/widgets/Legend"
], function (
Map,
MapView,
GeoJSONLayer,
Expand,
TimeSlider,
Legend) {
let layerViewAlertas;
let layerAlertas = new GeoJSONLayer({
url:
"https://raw.githubusercontent.com/Carlos29Blanco/Carlos29Blanco/develop/alertasNormal.geojson",
copyright: "Influenza Aviar",
title: "Influenza-Aviar",
// set the CSVLayer's timeInfo based on the date field
timeInfo: {
startField: "startDate", // name of the date field
interval: {
// set time interval to one day
unit: "days",
value: 7
let map = new Map({
basemap: "dark-gray-vector",
layers: [layerAlertas]
var view = new MapView({
map: map,
container: "viewDiv",
zoom: 3.6,
center: [30.68, 48.68]
// create a new time slider widget
// set other properties when the layer view is loaded
// by default timeSlider.mode is "time-window" - shows
// data falls within time range
let timeSliderAlertas = new TimeSlider({
container: document.createElement("div"),
playRate: 50,
/* mode: "cumulative-from-end", */
stops: {
interval: {
value: 7,
unit: "days",
// view.ui.add(timeSliderAlertas, "top-left");
// wait till the layer view is loaded
view.whenLayerView(layerAlertas).then(function (lv) {
layerViewAlertas = lv;
// start time of the time slider
let start = new Date();
start.setMonth(start.getMonth()-3);
// set time slider's full extent to
// until end date of layer's fullTimeExtent
timeSliderAlertas.fullTimeExtent = {
start: start,
end: new Date()
// We will be showing alerts with one day interval
// when the app is loaded we will show alerts that
// happened between
let end = new Date();
// end of current time extent for time slider
// showing alerts with one day interval
/* date.setDate( date.getDate() + 7) */
start.setDate(start.getDate() + 82);
// Values property is set so that timeslider
// widget show the first day. We are setting
// the thumbs positions.
timeSliderAlertas.values = [start, end];
// watch for time slider timeExtent change
timeSliderAlertas.watch("timeExtent", function () {
// only show alerts happened up until the end of
// timeSlider's current time extent.
layerAlertas.definitionExpression =
"startDate <= " + timeSliderAlertas.timeExtent.end.getTime();
// now gray out alerts that happened before the time slider's current
// timeExtent... leaving footprint of alerts that already happened
layerViewAlertas.effect = {
filter: {
timeExtent: timeSliderAlertas.timeExtent,
geometry: view.extent
excludedEffect: "grayscale(40%) opacity(20%)"
// add a legend for the alerts layer
let legendExpand = new Expand({
collapsedIconClass: "esri-icon-collapse",
expandIconClass: "esri-icon-expand",
expandTooltip: "Legend",
view: view,
content: new Legend({
view: view
expanded: false
view.ui.add(legendExpand, "top-left");
let timeSliderDropExpand = new Expand({
expandTooltip: "TimeSlider alertas",
view: view,
content: timeSliderAlertas,
expanded: true
view.ui.add(timeSliderDropExpand, "top-right");
expand.content = timeSlider.container
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
