Is there a way to hide the RF on a print map created using the JS API? I want to display only the scale bar and hide the RF text (ex. 1:600) which appears above.
George Hilton
Town of Queensbury, NY
Hi George. I'm not sure you can do this with the JS API. I believe you would need to create and use a custom Print template published from ArcMap or ArcGIS Pro.
Thanks Noah. I will look into creating a custom template.
