Create circle after loading of a div.
3265
12-03-2015 05:47 AM
ADITYAKUMAR1
Hi Users,
i am creating a circle on the map with the following lines of code.
   map.on("click", function (e) {
                  map.graphics.clear();
                  var circle = new Circle({
                      center: e.mapPoint,
                      radius: 1000,
                      radiusUnit: Units.MILES
                  var pictureMarkerSymbol = new PictureMarkerSymbol('Images/Bufferpin.png', 25, 25);
                  var point = new Point(e.mapPoint);
                  var pointGraphic = new Graphic(point, pictureMarkerSymbol);
                  map.graphics.add(pointGraphic);
                  // figure out which symbol to use
                  map.graphics.add(new Graphic(circle, fillSymbol));
                  map.setExtent(graphicsUtils.graphicsExtent(map.graphics.graphics));
                  queryMapService(circle);
But I need to perform the event after loading of a div where I will assign the units and radius length.
I have a button, on click of which a div opens where user can enter length and units and then on click on map the circle comes on the map.
Any suggestion in this will be helpful.
Thanks
Aditya Kumar
thejuskambi
Hello Aditya,
You can setup the map.onclick event online when the other inputs are filled.
or
you can have a variable which checks if that required value is present and if not then just escape from the click event without doing any thing.
Hope this was helpful.
Thejus
ADITYAKUMAR1
Hi Tehus,
Thanks for the response. But I do have other functionality like query,find where also a div comes on click of a button as well and in terms of validation anyway I need to ask the user to enter the value.
