Can you use dojo on.once() with map::update-end event?
3380
01-31-2017 11:56 AM
JerryGarcia
If so, can someone provide example code?
Thanks!
RobertScheitlin__GISP
Jerry,
   I use dojo on.once quit often in code.
on.once(map, "update-end", function(){
    // will only fire once...
thejuskambi
Hello Jerry,
I am not able to understand the objective of a example. on.once is a method in dojo, used to listen to an event only once. it would be similar to code below.
var handle = on(map, "click", function(evt){
   handle.remove();
It does not matter, which event. you can use on.once on any event, which you would like to listen just once.
JerryGarcia
Thanks.  But, it is not always that simple...    I want my code to fire only once. I have a couple callbacks when the event occurs.  So...  I need to wait until the callbacks are finished or, I was thinking, use the nifty on.once dojo functionality.  I'm still not clear how to invoke it's magic.
None of the following works:
on.once(...);
on(...).once();
handle.once();
Jerry,
by Anonymous User
Not applicable
This works as long as the dojo.on module is called first, like so:
require(["dojo/on"],
function(on) {
Thanks for this great tip!
JerryGarcia
I see.  Pretty simple.  Thanks!
