Binded two stored procedures from sql to same one map, but while coming to infowindow only one stored procedure is working, need to show different values depending on graphic
1408
06-26-2017 04:20 PM
Pa_Lotus
//Same information on every point only first Json Markers(data) is showing for all points
var map;
require([
], function (
Map, Scalebar, graphicsUtils, Extent, InfoTemplate, SimpleLineSymbol, Graphic, SimpleMarkerSymbol, Color, on, dom, Point, Search
var markers = JSON.parse('<%=GetData1() %>'); //getting data from sql
var outfall = JSON.parse('<%=GetData2() %>');//getting data from sql
map = new Map("FSMap", {
basemap: "osm",
center: [-y, x],
zoom: 6
map.on("load", addQueryResult);
function addQueryResult() {
if (markers && markers.length > 0) {
for (i = 0; i < markers.length; i++) {
var data = markers
var lat = data.latitude;
var long = data.longitude;
var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 4,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([128, 0, 128])));
var pt = new Point(long, lat);
var graphic = Graphic(pt, symbol, data);
map.graphics.add(graphic);
map.on("click", Pointdata);
function Pointdata(evt) {
if (evt.graphic) {
var latitude = evt.mapPoint.getLatitude();
var longitude = evt.mapPoint.getLongitude();
map.infoWindow.setTitle("Details");
map.infoWindow.setContent(evt.graphic.attributes.FId+ '<br>' + 'Address:' + evt.graphic.attributes.StreetAddress
map.infoWindow.show(evt.mapPoint, map.getInfoWindowAnchor(evt.screenPoint));
if (outfall && outfall.length > 0) {
for (i = 0; i < outfall.length; i++) {
var Info = outfall
var lati = Info.LatitudeDecimal;
var longi = Info.LongitudeDecimal;
var green = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 11,
new Color([0, 128, 0]), 2));));
var pnt = new Point(longi, lati);
var graphi = Graphic(pnt, green, data);
map.graphics.add(graphi);
map.on("click", Outfalldata);
function Outfalldata(evt) {
if (evt.graphi) {
map.infoWindow.setTitle("OutfallDetails");
map.infoWindow.setContent(evt.graphi.attributes.PId
thejuskambi
Hello Malla,
Please understand what you are writing or copying.
When you are creating the instance of the graphic
You are passing the attribute informations into the graphics which is reterieved from looping through the variable "markers".
    var data = markers[i]
Now, that you have created a new variable "outfall" and looping through them to create new objects.
   var Info = outfall
but you are still using the data from previous loop. you would need to use the correct object instances.
Pa_Lotus
thejus.kambi‌ If you can help me, Have a look in to code once
thejuskambi
Hello Malla,
   var Info = outfall
