Why Would Vector Basemap "streets-vector" Not Display in IE11?
3843
8
10-05-2016 05:12 PM
KirstenFrost_Andersen
I have one computer that will not display an ESRI vector base map:
var map = new Map({
              basemap: "streets-vector"
It works on all other computers I have tried, just one computer for all users won't display this base map.  The "topo" and "streets" base maps work just fine.  Any ideas?  I'm guessing it's a settings issue, but I am simply helping debug this app, I am not very familiar with ArcGIS for JavaScript API. I haven't found anything different in Compatibility View on a computer that works and this one that doesn't.  Same with the Internet Options settings.  The computer is on Windows 8 and the one I'm testing against that does work is Windows 10.  Both IE11.  Firefox and Chrome display the basemap just fine.  I welcome any ideas on what to look for, either in IE settings or in code.
RobertScheitlin__GISP
Kirsten,
   Make sure that the JS code specifies the document mode (line 5):
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge, chrome=1" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script src="https://js.arcgis.com/3.18/"></script>
    <script>
      var map;
      require(["esri/map", "dojo/domReady!"], function(Map) {
        map = new Map("map", {
          basemap: "streets-vector",  //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
          center: [-122.45, 37.75], // longitude, latitude
          zoom: 13
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
Thanks Robert for the response!  It looks like we have that in the html file:
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="X-UA-Compatible" content="IE=Edge">
    <meta charset="utf-8">
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
    <title>Average Daily Traffic</title>
    <!-- Include ArcGIS stylesheets -->
    <link rel="stylesheet" href="http://js.arcgis.com/4.0/esri/css/main.css">
    <!-- Include jquery -->
    <script type="text/javascript" src="../jquery/jquery-1.11.3.min.js"></script>
    <script type="text/javascript" src="../jquery/jquery-ui-1.10.4/ui/jquery-ui.js"></script>
    <!-- Include ArcGIS API -->
    <script src="https://js.arcgis.com/4.0/"></script>
    <!-- Include ADT JavaScript-->
    <script type="text/javascript" src="ADT.js"></script>
    <!-- Include ADT stylesheets -->
    <link rel="stylesheet" href="ADT.css">
</head>
The JS file is included and here's a snippet of the code:
function (
        Map,
        MapView,
        Extent,
        SpatialReference,
        FeatureLayer,
        PopupTemplate,
        Legend,
        Home,
        on,
        dom,
        domAttr,
        domConstruct
          var map = new Map({
              basemap: "streets"
          var view = new MapView({
              container: "viewDiv",
              map: map,
              center: [-117.427677, 47.644390],
              zoom: 9,
              //                      padding: {
              //                          right: 200
              popup: {
                  //                         dockEnabled: true,
                  dockOptions: {
                      breakpoint: false,   // to prevent automatic docking when screen gets small
                      position: "bottom-left",
          view.constraints = {
              minScale: 2000000,  // User cannot zoom out beyond a scale of 1:2,000,000
              maxScale: 0,  // User can overzoom tiles
              rotationEnabled: false  // Disables map rotation
Would you concur, or did I overlook something?
SteveCole
Honored Contributor
For both machines that have IE11, hit F12 and compare the emulation settings. See if anything is different between the computer that works and the one that won't.
Good thought!  I'll take a look.
Steve, apparently the computer that doesn't work doesn't see the "via x-ua-compatible" meta tag.  So that may be the key, especially given Robert's suggestions.  So I need to figure out why not.
This is from a computer that works:
Computer that displays basemap.
This is from a computer that doesn't display the basemap on the same network:
Computer that does not display basemap.
SteveCole
Honored Contributor
If you manually change the setting within Emulation, does the basemap appear?
Kirsten,
   OK you neglected to mention you were using 4.x JS API. When I specify the document mode I have not issue with this code on IE 11.
<!DOCTYPE html>
<html>
<head>
  <title>Get started with MapView - Create a 2D map - 4.0</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.0/esri/css/main.css">
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "dojo/domReady!"
    ], function(Map, MapView) {
      var map = new Map({
          map: map,
          zoom: 9,
          //                      padding: {
          //                          right: 200
          popup: {
              dockOptions: {
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Is the machine that is failing running this website over an Intranet url or a true www url? IE can default to a certain document mode when using an Intranet url.
Sorry, I overlooked that detail.
The machine is running over a true inTERnet URL, however it IS connected to our internal network.  That might be a test, to see if it works when connected to a network outside of the office.  Good thought!
