Viewer inset outline
2119
07-23-2020 12:06 AM
JethroLeevers
The new viewer seems to have a style on focus ( .esri-view-surface--inset-outline ), this adds a border to the viewer, is there any way to stop this from happening, I tried removing it from the dom on view.when but it seemed to re-add the style on focus.
Egge-Jan_Pollé
MVP Regular Contributor
Hi Jethro Leevers,
Did you see this thread? [arcgis js api 4.*] remove blue frame/outline around MapView
There Robert Scheitlin, GISP‌ suggests the following solution, using CSS:
.esri-view .esri-view-surface--inset-outline:focus::after {
  outline: none !important;
HTH,
Egge-Jan
Egge-Jan_Pollé
Hi Jethro Leevers,
HTH,
Egge-Jan
Nicolas_
I think this solution stopped working in version 4.27
MiroslavUmlauf
Indeed it stopped working due to change of DOM inside view from version 4.26 to 4.27. Updated CSS adjusted by this change:
.esri-view .esri-view-surface--touch-none:focus::after {
