[arcgis js api 4.*] remove blue frame/outline around MapView
8611
7
07-12-2019 07:24 AM
DivisionSIG
Since javascript API vV4.* there is a blue outline around the map, when we interact with the view.
You can see this on the sample app https://developers.arcgis.com/javascript/latest/sample-code/intro-mapview/index.html Just move the map and you'll notice that blue outline around the view.
Do you know how to remove or disable that feature ?
thank you all
RobertScheitlin__GISP
Focus rectangles are an important part of accessibility. But if you really want to remove it anyway.
.esri-view .esri-view-surface--inset-outline:focus::after {
  outline: none !important;
DivisionSIG
thank you, it worked
MiroslavUmlauf
Indeed it stopped working due to change of DOM inside view from version 4.26 to 4.27. Updated CSS adjusted by this change:
.esri-view .esri-view-surface--touch-none:focus::after {
SebastianKrings
does not seem to work anymore in 5.x, any new idea?
miro_aus
Adjusted for version 5.0.
.esri-view .esri-view-surface:focus::after,
.esri-view .esri-view-surface:focus-visible::after {
 Just a small accessibility note: while removing the focus outline may look better visually, it can make keyboard navigation less accessible. Keeping some subtle visible focus indicator is usually a better approach.
  outline: 2px solid rgba(255, 255, 255, 0.75);
  outline-offset: -4px;
Sage_Wall
If / when you migrate to use the arcgis-map component, we added a css variable to change the focus color.  If you are not concerned about accessibility you could set it to be transparent
    arcgis-map {
      --arcgis-view-color-focus: transparent;
SebastianKrings
Hi, thanks.
That does work.
Accessability is a thing, yes, but the permanent toggling of the Map-Frame, when doing different interactions with tools, was irritating pretty much.
