Select by polygon 4.14
2441
03-12-2020 05:41 AM
Vakhtang_Zubiashvili
Hi guys
I am trying to select polygon features using sketchViewModel, using this sample code.
I removed CSV layer with FeatureLayer.
But now, when i select features, in table i see only OBJECTID, it applies column headers for other fields, but without data.
see Pic. for error and Code below.
Thank you in advance.
Select by polygon
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Highlight features by geometry - 4.14</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.14/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.14/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
      #info,
      #gridDisplay {
        position: absolute;
        bottom: 0;
        left: 0;
        height: 35%;
        background-color: white;
        border-color: grey;
        width: 100%;
        font-size: 14px;
      #gridDisplay {
        z-index: 80;
      #info {
        z-index: 90;
        font-size: 16px;
        padding-left: 20px;
      #info * {
        padding-right: 20px;
      .info {
        line-height: 20px;
        padding-left: 5px !important;
      .dgrid-header,
      .dgrid-header-row {
        background-color: #eee;
        color: #57585a;
      .dgrid-row-even {
        background-color: #f7f8f8;
      .dgrid-row-odd {
        background-color: #efefef;
      .dgrid-selected {
        background: #b4daf5;
      .dgrid-row {
        border: none;
    </style>
    <script>
      require([
        "esri/WebMap",
        "esri/views/MapView",
        "esri/layers/FeatureLayer",
        "esri/layers/GraphicsLayer",
        "esri/widgets/Sketch/SketchViewModel",
        "esri/Graphic",
        "esri/widgets/Legend",
        "esri/widgets/Expand",
        "esri/widgets/FeatureForm",
        "dgrid/OnDemandGrid",
        "dgrid/extensions/ColumnHider",
        "dojo/store/Memory",
        "dstore/legacy/StoreAdapter",
        "dgrid/Selection"
      ], function(
        WebMap,
        MapView,
        FeatureLayer,
        GraphicsLayer,
        SketchViewModel,
        Graphic,
        Legend,
        Expand,
        FeatureForm,
        OnDemandGrid,
        ColumnHider,
        Memory,
        StoreAdapter,
        Selection
        let map,
          view,
          flLayer,
          csvLayerView,
          polygonGraphicsLayer,
          sketchViewModel,
          highlight,
          grid;
        const gridDiv = document.getElementById("grid");
        const infoDiv = document.getElementById("info");
        // create new map, view and csvlayer
        setupTheView();
        // create a new sketchviewmodel, setup it properties
        // set up the click event for the select by polygon button
        setUpSketchViewModel();
        sketchViewModel.on("create", function(event) {
          if (event.state === "complete") {
            // this polygon will be used to query features that intersect it
            polygonGraphicsLayer.remove(event.graphic);
            selectFeatures(event.graphic.geometry);
        const gridFields = [
          "OBJECTID",
          "Req_Code",
          "abonentebis_raodenoba",
          "dasaxeleba",
          "Semqmneli",
          "statusi"
        // create a new datastore for the on demandgrid
        // will be used to display attributes of selected features
        const dataStore = new StoreAdapter({
          objectStore: new Memory({
            idProperty: "OBJECTID"
        // create a grid with given columns once the csvlayer is loaded
        csvLayer
          .when(function() {
            // create a grid with columns specified in gridFields variable
            createGrid(csvLayer.fields);
            // get a reference the csvlayerview when it is ready. It will used to do
            // client side queries when user draws polygon to select features
            view.whenLayerView(csvLayer).then(function(layerView) {
              csvLayerView = layerView;
          .catch(errorCallback);
         * Selects features from the csv layer that intersect
         * a polygon that user drew using sketch view model
        function selectFeatures(geometry) {
          view.graphics.removeAll();
          if (csvLayerView) {
            // create a query and set its geometry parameter to the
            // polygon that was drawn on the view
            const query = {
              geometry: geometry,
              outFields: ["*"]
            // query graphics from the csv layer view. Geometry set for the query
            // can be polygon for point features and only intersecting geometries are returned
            csvLayerView
              .queryFeatures(query)
              .then(function(results) {
                const graphics = results.features;
                // if the grid div is displayed while query results does not
                // return graphics then hide the grid div and show the instructions div
                if (graphics.length > 0) {
                  // zoom to the extent of the polygon with factor 2
                  view.goTo(geometry.extent.expand(2));
                  gridDiv.style.zIndex = 90;
                  infoDiv.style.zIndex = 80;
                  document.getElementById("featureCount").innerHTML =
                    "<b>Showing attributes for " +
                    graphics.length.toString() +
                    " features </b>";
                } else {
                  gridDiv.style.zIndex = 80;
                  infoDiv.style.zIndex = 90;
                // remove existing highlighted features
                if (highlight) {
                  highlight.remove();
                // highlight query results
                highlight = csvLayerView.highlight(graphics);
                // get the attributes to display in the grid
                const data = graphics.map(function(feature, i) {
                  return (
                    Object.keys(feature.attributes)
                      .filter(function(key) {
                        // get fields that exist in the grid
                        return gridFields.indexOf(key) !== -1;
                      // need to create key value pairs from the feature
                      // attributes so that info can be displayed in the grid
                      .reduce(function(obj, key) {
                        obj[key] = feature.attributes[key];
                        return obj;
                // set the datastore for the grid using the
                // attributes we got for the query results
                dataStore.objectStore.data = data;
                grid.set("collection", dataStore);
         * fires when user clicks a row in the grid
         * get the corresponding graphic and select it
        function selectFeatureFromGrid(event) {
          // close view popup if it is open
          view.popup.close();
          // get the ObjectID value from the clicked row
          const row = event.rows[0];
          const id = row.data.OBJECTID;
          // setup a query by specifying objectIds
          const query = {
            objectIds: [parseInt(id)],
            outFields: ["*"],
            returnGeometry: true
          // query the csvLayerView using the query set above
          csvLayerView
              // remove all graphics to make sure no selected graphics
              // create a new selected graphic
              const selectedGraphic = new Graphic({
                geometry: graphics[0].geometry,
                symbol: {
        type: "simple-fill", // autocasts as new SimpleFillSymbol()
        color: "yellow",
        style: "solid",
        outline: {
          color: "red",
          width: 1
              // add the selected graphic to the view
              // this graphic corresponds to the row that was clicked
              view.graphics.add(selectedGraphic);
         * Creates a new grid. Loops through poverty
         * csvLayer's fields and creates grid columns
         * Grid with selection and columnhider extensions
        function createGrid(fields) {
          var columns = fields
            .filter(function(field, i) {
              if (gridFields.indexOf(field.name) !== -1) {
                return field;
            .map(function(field) {
              if (field.name === "__OBJECTID") {
                return {
                  field: field.name,
                  label: field.name,
                  sortable: true,
                  hidden: true
              } else {
                return {
                  field: field.name,
                  label: field.alias,
                  sortable: true
          // create a new onDemandGrid with its selection and columnhider
          // extensions. Set the columns of the grid to display attributes
          // the hurricanes cvslayer
          grid = new (OnDemandGrid.createSubclass([Selection, ColumnHider]))(
              columns: columns
            "grid"
          // add a row-click listener on the grid. This will be used
          // to highlight the corresponding feature on the view
          grid.on("dgrid-select", selectFeatureFromGrid);
         * Sets up the sketchViewModel. When user clicks on the select by polygon
         * button sketchViewModel.create() method is called with polygon param.
        function setUpSketchViewModel() {
          // polygonGraphicsLayer will be used by the sketchviewmodel
          // show the polygon being drawn on the view
          polygonGraphicsLayer = new GraphicsLayer();
          map.add(polygonGraphicsLayer);
          // add the select by polygon button the view
          view.ui.add("select-by-polygon", "top-left");
          const selectButton = document.getElementById("select-by-polygon");
          // click event for the button
          selectButton.addEventListener("click", function() {
            clearUpSelection();
            view.popup.close();
            // ready to draw a polygon
            sketchViewModel.create("polygon");
          // create a new sketch view model set its layer
          sketchViewModel = new SketchViewModel({
            view: view,
            layer: polygonGraphicsLayer,
            pointSymbol: {
        color: "yellow",
        style: "solid",
        outline: {
          color: "red",
          width: 1
        function clearUpSelection() {
          grid.clearSelection();
         * Sets up the view. WebMap with winkel III projection
         * basemap and hurricanes CsvLayer is added to the view.
        function setupTheView() {
          const url =
          "http://1ocalhost:6080/arcgis/rest/services/test/Request_Area/FeatureServer/0";
          csvLayer = new FeatureLayer({
            title: "Hurricanes",
            url: url,
            copyright: "GWP",
          map = new WebMap({
            // contains a basemap with a Winkel III projection
            // the CSVLayer coordinates will re-project client-side
            portalItem: {
            layers: [csvLayer]
          view = new MapView({
            container: "viewDiv",
            map: map,
            highlightOptions: {
              color: "#2B65EC",
              fillOpacity: 0.4
            padding: {
              bottom: infoDiv.clientHeight // Same value as the #infoDiv height in CSS
          const legendExpand = new Expand({
            view: view,
            content: new Legend({
              view: view,
              style: "card"
          view.ui.add(legendExpand, "top-left");
          view.popup.watch("visible", function(newValue) {
            if (newValue) {
              clearUpSelection();
        function errorCallback(error) {
          console.log("error:", error);
    </script>
  </head>
  <body>
    <div id="viewDiv">
      <div
        id="select-by-polygon"
        class="esri-widget esri-widget--button esri-widget esri-interactive"
        title="Select features by polygon"
        <span class="esri-icon-checkbox-unchecked"></span>
      </div>
      <div id="info" class="esri-widget">
        <span class="info"> <b>Instructions</b> </span> <br />
        <ul>
          <li>
            Select features using select by polygon tool. Attributes of selected
            features will be displayed here.
          </li>
          <br />
          <li>
            Click on a row to select a feature associated with it or click on a
            feature to display its popup.
          </li>
        </ul>
      </div>
      <div id="gridDisplay">
        <span class="info" id="featureCount"></span>
        <div id="grid"></div>
      </div>
    </div>
  </body>
</html>
KenBuja
MVP Esteemed Contributor
If you don't specify the outFields property when creating a FeatureLayer, it will only return ObjectID
  url: url,
  copyright: "GWP",
  outFields: ["*"]
KenBuja
  url: url,
  copyright: "GWP",
  outFields: ["*"]
Oops, how i couldn't notify, thanks ken
