I’m currently using ArcGIS JavaScript API 4.5 but hope to move to 4.9 soon. Either way, the issue is the same even on my test 4.9 app.
I want graphics, such as draw, to show in the printed map but not in the legend. The JS 3.x API would do this but 4.x makes a legend item which says “polygonLayer” and the graphic called “Override 1”. This makes the printed map look silly. (see attached image)
I followed advice found here and intercepted the Print request and removed my graphics layers from the operationalLayers in the Web_Map_as_JSON. However, this also removes the graphics from the map.
So in 4.x, is there a way to keep graphics in the map but remove them from the legend?
Thanks!
