Legend Not Rendered on Legend Widget
818
04-08-2021 11:04 AM
pegafal
When using ES Module @Anonymous User/core 4.18.1 for angular project, Legend with visual variable was not rendered properly.
The legend worked when doing in memory build. But when doing production build by issuing command
ng build --configuration=production
the legend didn't show and this error was shown on Chrome console.legend_error.PNG
Step to reproduced the error
1) Create new project by using latest angular cli
ng new my-project
cd my-project
ng generate c map-test
2) Add this simple code to add legend with visual variable
    esriConfig.assetsPath = '/assets';
    const map = new Map({
      basemap: 'topo-vector'
    const view = new MapView({
      map: map,
      container: 'map-container',
      center: [-84, 32],
      zoom: 5,
      constraints: {
        rotationEnabled: false
    const renderer: any = {
      type: 'simple',
      symbol: {
        type: 'simple-marker',
        outline: {
          width: '0px'
      visualVariables: [{
        type: 'color',
        valueExpressionTitle: `Legend Title`,
        field: 'some_field',
        stops: [{
          value: 0, color: '#ff0000'
          value: 20000, color: '#0f0'
    const legendLayer = new FeatureLayer({
      source: [],
      fields: [{
        type: 'oid'
      opacity: 0.5,
      listMode: 'hide',
      objectIdField: 'ObjectID',
      geometryType: 'point',
      title: 'My legend',
      visible: true
    legendLayer.renderer = renderer;
    map.add(legendLayer);
    const legends = new Legend({
      view: view
    view.ui.add(legends, {
      position: 'bottom-right'
  3) run production build
PS. I tested using latest angular version (11) as well as angular version 8
AndyGup
There's been a few bugs fixed that might be related to your issue. Try testing using 4.19-next build, which will be released to production in a few weeks. With 4.19 the assets will load via CDN by default, but you can still load them locally if needed. So comment out your assetsPath code when you try this upgrade:
npm i @Anonymous User/core@next
Also, here's a working repo you can use to test: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-angular-cli
AndyGup
pegafal
Yes, 4.19 seems to fix this issue.
