When using ES Module @Anonymous User/core 4.18.1 for angular project, Legend with visual variable was not rendered properly.
The legend worked when doing in memory build. But when doing production build by issuing command
ng build --configuration=productionthe legend didn't show and this error was shown on Chrome console.legend_error.PNG
Step to reproduced the error
1) Create new project by using latest angular cli
ng new my-project
cd my-project
ng generate c map-test2) Add this simple code to add legend with visual variable
esriConfig.assetsPath = '/assets';
const map = new Map({
basemap: 'topo-vector'
const view = new MapView({
map: map,
container: 'map-container',
center: [-84, 32],
zoom: 5,
constraints: {
rotationEnabled: false
const renderer: any = {
type: 'simple',
symbol: {
type: 'simple-marker',
outline: {
width: '0px'
visualVariables: [{
type: 'color',
valueExpressionTitle: `Legend Title`,
field: 'some_field',
stops: [{
value: 0, color: '#ff0000'
value: 20000, color: '#0f0'
const legendLayer = new FeatureLayer({
source: [],
fields: [{
type: 'oid'
opacity: 0.5,
listMode: 'hide',
objectIdField: 'ObjectID',
geometryType: 'point',
title: 'My legend',
visible: true
legendLayer.renderer = renderer;
map.add(legendLayer);
const legends = new Legend({
view: view
view.ui.add(legends, {
position: 'bottom-right'
});3) run production build
PS. I tested using latest angular version (11) as well as angular version 8
There's been a few bugs fixed that might be related to your issue. Try testing using 4.19-next build, which will be released to production in a few weeks. With 4.19 the assets will load via CDN by default, but you can still load them locally if needed. So comment out your assetsPath code when you try this upgrade:
npm i @Anonymous User/core@next
Also, here's a working repo you can use to test: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-angular-cli
Yes, 4.19 seems to fix this issue.
