How to update / add feature attributes?
491
11-16-2022 01:31 PM
AndrewMurdoch1
Occasional Contributor II
Good Day
I already know about setAttribute, my question is how save the update so my attribute become available?
this.grabData().then(() => {
	this.queryAllFeatures(this._layers[0]).then((features: Graphic[]) => {
  		features.forEach((feature, idx) => {
    			const matchedFeature = this.data.find(d => d.x === feature.attributes.x)
    			if (matchedFeature) {
			      const value1 =
				matchedFeature?.box?.find(i => i.type === 'a').value ?? 0;
				feature.setAttribute('someValue', Number(value1));
				// Repeated X times
If I do this, and try to reference "someValue" I get an error that it doesn't exist, so I tried to use "applyEdits" to update the value:
this._layers[0].applyEdits({ updateFeatures: features })
    .then((editsResult) => {
        console.log('Edit Results');
        console.log(editsResult);
    .catch((error) => {
        console.log("error = ", error);
Which works, but I still don't see my new attributes.  Previous I was getting an error from applyEdits, but I resolved that problem!
Can anyone see what I'm doing wrong?
Thanks
UndralBatsukh
Hi there,
It is hard to suggest anything without a repro case. Are you working with a FeatureLayer that references a feature service or is this a client-side FeatureLayer? You should see the updated values for feature services without having to do anything as long as applyEdits resolves successfully. For client-side featureLayer, you have to query the updated features once applyEdits resolves successfully.
It is explained in this document: https://next.sites.afd.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#appl...
This very simple sample shows and explains this workflow: https://developers.arcgis.com/javascript/latest/sample-code/layers-featurelayer-collection-edits/
AndrewMurdoch1
Good Day
Thanks for the reply, I'm using a Hosted Feature Layer, please see this more complete example:
addGISFeatureAttributes(layer: FeatureLayer) {
    return new Promise((r) => {
      console.time('correlationLook10k');
      this.queryAllFeatures(layer).then((features: Graphic[]) => {
              const value1 =
                matchedFeature?.find(m => m.type === 'v1').value ?? 0;
              const value2 =
              const value3 =
              feature.setAttribute('v1', Number(value1));
              feature.setAttribute('v2', Number(value2));
              feature.setAttribute('v3', Number(value3));
              feature.attributes.v4 = Number(value3);
          layer.applyEdits({updateFeatures: features}).then((updateResults) => {
            console.log('Update Results');
            console.log(updateResults);
            const query = {
              where: '1=1',
              outFields:['*'],
              returnGeometry: true,
              maxRecordCountFactor: 5
            const objectIds = [];
            updateResults.updateFeatureResults.forEach((item) => {
              objectIds.push(item.objectId);
            console.log('Object Ids');
            console.log(objectIds);
            layer.queryFeatures(query).then((results) => {
              console.log(results.features.length, "features have been added.");
              console.timeEnd('correlationLook10k');
              r(results);
            }).catch((error) => {
              console.log('Query Feature Error');
              console.log(error);
            console.log('Upload Error');
            console.log(error);
  showPortalFeatureLayerByYear(year: number = new Date().getFullYear()) {
    let layerId = "SOME PORTAL ID"
    this._layers = [];
    new FeatureLayer({
      portalItem: {
      outFields: ['*']
    }).load().then((layer) => {
      this.addGISFeatureAttributes(layer).then((features: FeatureSet) => {
        console.log('Features');
        console.log(_.cloneDeep(features));
        return new FeatureLayer({
          source: features.features,
          fields: features.fields,
          renderer: null,
          spatialReference: {
            wkid: 102100
          outFields: ["*"]
          this._layers.push(layer);
          this.renderHostedFeatureLayer();
Should I have my new layer with v1 -> v4?  This does the applyEdits, and this does the query stage.  One thing I've noticed, this is slow, ~60 seconds for 10k assets, so this generally not recommended?
Thanks
ReneRubalcava
Can you verify that the fields you are trying to update are in the the layers fields array?
AndrewMurdoch1
Yes, they exist, the features all contain v1 -> v4, v1 is always a number from 0 - 100 in string form, and I'm doing feature.setAttribute('v1', "SUPERRANDOMSET").  After that logic runs v1 is still "0" - "100", when I expect it to be "SUPERRANDOMSET".
Could there be a problem running the update on a layer that was created from ArcGIS Online? I've been able to do this with client side graphics when I build them manually.
AndrewMurdoch1
The other question I should ask, is this even recommended or practical to do?  We could have layers with 100k+ features in them, and we'd want to perform the same kind of step, is there anyway to do this at scale and with minimal latency?
