Access Attribute of individual feature in the feature layer create using client side graphics.
992
11-16-2022 07:30 PM
HrithikKhangarot
I have been trying to color individual colors graphics which are added using client-side graphics in the feature layer. but the symbol property of the graphic is overwritten by the renderer property of the feature layer.
I have taken the source as the array of graphics with a symbol property of simpleMarkerSymbol . simpleMarkerSymbol Provides different colors to the symbol based on the values it gets from the backend. So I want to color individual graphics once the cluster_number is equals to 1.
this.mapNodes.forEach((node,i)=>{  // this.mapNodes is the data from API
      this.simpleMarkerSymbol = {
          type: "simple-marker",
          color: node.colorCode,
          style: "circle",
          outline: {
            width: 3
      let point = new Point({ x: node.longitude, y: node.lattitude });
      let graphic = new Graphic({
        geometry: point,
        symbol: this.simpleMarkerSymbol,
        attributes: {
          color:node.colorCode
      this.graphics.push(graphic);
    var action:any = {
      title: "Open-Chart",
    this.nodeLayer=new FeatureLayer({
      featureReduction:MapViewConstant.clusterConfig,
      source:this.graphics,
      fields:MapViewConstant.fields,
      objectIdField:MapViewConstant.OBJECT_ID,
      popupTemplate: {
        title: "{name}",
        actions:[action]
    renderer:MapViewConstant.renderer // it provides grey color to all the features
    this.Map.add(this.nodeLayer);
ReneRubalcava
Esri Frequent Contributor
Features in a FeatureLayer can only be symbolized by the renderer of the FeatureLayer.
We have a guide on visualization that might help.
https://developers.arcgis.com/javascript/latest/visualization/
From your description, it sounds like you might want to use a Unique Value Renderer.
https://developers.arcgis.com/javascript/latest/visualization/data-driven-styles/unique-types/
