How do I call my SOE using the JS API?
1341
07-09-2020 09:39 AM
chrisweaves
I have an SOE deployed and can call it fine using a browser using the following:
https://server/arcgis/rest/services/Testing/TestLayer/MapServer/exts/FeatureCountSOE/findNearbyFeatu...
That works fine and sends a json response with the feature count.
What I need is to replicate the call above but using the JS API, I have tried a few things but none seem to pass append the REST endpoint with the required parameters (layerId, location and distance), here's what I tried
var queryTask = new QueryTask({
    url:     "https://server/arcgis/rest/services/Testing/TestLayer/MapServer/exts/FeatureCountSOE/findNearbyFeatures",
    layerId: 0,
    distance: 10000,
    location: "{'x':0,'y':0,'spatialReference':{'wkid':3857}}",
    f: "json"
var query = new Query();
query.outFields = ["*"];
queryTask.execute(query).then(function(results){
    alert(results);
Am I way off the mark?  Feels like it 😕
Thanks for your help!
RobertScheitlin__GISP
Chris,
   Yes a query task is not the right class to use. You need to use esriRequest.
request | ArcGIS API for JavaScript 4.15
Request data from a remote server | ArcGIS API for JavaScript 4.15
Chris,
