Having Issue on Getting Lat & Long of Multi Point Added to The Map
1466
01-17-2017 03:18 PM
BehrouzHosseini
Customizing this Esri Sample I am able to get  Lat and Long of new added Point to the Map at
function addToMap(evt) {
 var symbol;
 toolbar.deactivate();
 map.showZoomSlider();
 switch (evt.geometry.type) {
 case "point":
 symbol = new SimpleMarkerSymbol();
 var mp = webMercatorUtils.webMercatorToGeographic(evt.geometry);
 var lat = mp.x;
 var long = mp.y;
 console.log(lat, long);
 var point = new Point(lat, long);
 var graphic = new Graphic(point, symbol);
 pointGraphicLayer.add(graphic);
 break;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Now I need to do the same process for Multipoint class as
case "multipoint":
 console.log(mp.points);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
but I am getting this error
can you please let me know how I can get a list of lat and long of multi point?
Thanks
Update
I also tried this
case "multipoint":
console.log(this.points);
break;
 but the console.log() is not printing out any thing however I am not getting error neither
Tags (1)
RobertScheitlin__GISP
Bengi,
  Your likely issue is that you did not change the switch block to handle the point and multipoint separately:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="width=device-width,user-scalable=no">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Maps Toolbar</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.19/dijit/themes/nihilo/nihilo.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.19/esri/css/esri.css">
    <style>
      html, body, #mainWindow {
        font-family: sans-serif;
        height: 100%;
        width: 100%;
      html, body {
        margin: 0;
        padding: 0;
      #header {
        height: 80px;
        overflow: auto;
        padding: 0.5em;
    </style>
    <script src="https://js.arcgis.com/3.19/"></script>
    <script>
      var map, toolbar, symbol, geomTask;
      require([
        "esri/map",
        "esri/toolbars/draw",
        "esri/graphic",
        "esri/geometry/webMercatorUtils",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "dojo/parser", "dijit/registry",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dijit/form/Button", "dijit/WidgetSet", "dojo/domReady!"
      ], function(
        Map, Draw, Graphic, webMercatorUtils,
        SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
        parser, registry
        parser.parse();
        map = new Map("map", {
          basemap: "streets",
          center: [-15.469, 36.428],
          zoom: 3
        map.on("load", createToolbar);
        // loop through all dijits, connect onClick event
        // listeners for buttons to activate drawing tools
        registry.forEach(function(d) {
          // d is a reference to a dijit
          // could be a layout container or a button
          if ( d.declaredClass === "dijit.form.Button" ) {
            d.on("click", activateTool);
        function activateTool() {
          var tool = this.label.toUpperCase().replace(/ /g, "_");
          toolbar.activate(Draw[tool]);
          map.hideZoomSlider();
        function createToolbar(themap) {
          toolbar = new Draw(map);
          toolbar.on("draw-end", addToMap);
          var symbol;
            case "point":
              var lat = mp.x;
              var long = mp.y;
              break;
            case "multipoint":
              break;
            case "polyline":
              symbol = new SimpleLineSymbol();
              break;
            default:
              symbol = new SimpleFillSymbol();
              break;
          var graphic = new Graphic(evt.geometry, symbol);
          map.graphics.add(graphic);
    </script>
  </head>
  <body class="nihilo">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
      <span>Draw:<br /></span>
      <button data-dojo-type="dijit/form/Button">Point</button>
      <button data-dojo-type="dijit/form/Button">Multi Point</button>
      <button data-dojo-type="dijit/form/Button">Line</button>
      <button data-dojo-type="dijit/form/Button">Polyline</button>
      <button data-dojo-type="dijit/form/Button">Polygon</button>
      <button data-dojo-type="dijit/form/Button">Freehand Polyline</button>
      <button data-dojo-type="dijit/form/Button">Freehand Polygon</button>
      <button data-dojo-type="dijit/form/Button">Arrow</button>
      <button data-dojo-type="dijit/form/Button">Triangle</button>
      <button data-dojo-type="dijit/form/Button">Circle</button>
      <button data-dojo-type="dijit/form/Button">Ellipse</button>
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
  </div>
  </body>
</html>
Bengi,
<!DOCTYPE html>
<html>
  <head>
    <style>
        height: 100%;
        width: 100%;
      html, body {
        margin: 0;
        padding: 0;
      #header {
        height: 80px;
        overflow: auto;
        padding: 0.5em;
    </style>
    <script>
      require([
        "esri/map",
        "esri/graphic",
      ], function(
        parser, registry
        parser.parse();
          basemap: "streets",
          zoom: 3
          var symbol;
            case "point":
              var lat = mp.x;
              var long = mp.y;
              break;
            case "multipoint":
              break;
            case "polyline":
              break;
            default:
              break;
    </script>
  </head>
    </div>
  </div>
  </body>
</html>
BehrouzHosseini
Thanks Robert, this is working perfectly. Just one more question?  Can we use the same mechanism to get vertices of Polygons and Line or Polylines , as well?
Bengi,
   Yes you should be able to if you loop over the points in those geometries.
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
