Graphic Layer Precision (?) problem when upgrading to 4.11
1327
06-26-2019 11:19 AM
RodrigoFelga
I'm updagrading my application from js API version 4.5 to version 4.11.
In a tool of the aplication I draw a box on the map and the make a queryto get the features that intersect that box. Then I get those features and add them to a GraphicsLayer.
My problem is that in the APi version 4.11 the graphic is a little misplaced, it's a very little distortion but it affects others functions of the application. It's only noticiable when the scale is very close.
I checked the server response from the QueryTask and they are the same for both versions of the API.
See the example below, first I select a line on the API version 4.5 and the result is that:
Now I select the same feature using API version 4.11 and the result is that:
The red line is my GraphicsLayer and in the API 4.11 is a little below that where it should be.
 Thanks for any help.
Tags (1)
RodrigoFelga
I noticed that the issued occurred between version 4.9 to 4.10. The code works on 4.9
RobertScheitlin__GISP
The urls for 4.12 are active so you should see if they fixed it in 4.12.
RodrigoFelga
Thanks Robert, but it's not solved in 4.12.
Then you need to contact tech support and file a bug.
