Evento no mapa obter latitude e longitude
2223
05-13-2016 07:57 PM
Valderli_JorgePiontekowski
Estou utilizando ArcGIS API JavaScript 4.0 e estou tentando retornar com mapPoint a latitude e longitude a partir do mapa, mas única maneira que consegui foi com "click":
    view.on("click", function(evt) {
        // Get the coordinates of the click on the view
        var lat = (evt.mapPoint.latitude).toFixed(2);
        var lon = (evt.mapPoint.longitude).toFixed(2);
        dom.byId("info").innerHTML = lat + ", " + lon;
Gostaria de saber se é possível fazer com evento ao passar o mouse (por exemplo: load, mosue-over, hover)?
obrigado
AdrianWelsh
MVP Honored Contributor
Hi Valderli,
From using Google Translate, I attempted to read this in English.
Can you not just user the "mouse-over" event in the JavaScript in place of the "click" event? Does this not do anything?
There is an example in here:
Feature layer hover | ArcGIS API for JavaScript
This one mentions the mouse-over event.
I found here:
Show info window on mouse hover | ArcGIS API for JavaScript
Information on mouse hovering.
I hope this helps.
