Custom WebSocket Server + StreamLayer + JS API >= 4.9
11056
13
03-05-2019 05:03 AM
Raul_Jimenez
From this question we realized that the StreamLayer documentation explained that the following could be done:
You may also use your own web socket server, as long as it emits geographic features in the Esri JSON format.
So Jorge Barrachina Gutiérrez and I are just doing an experiment to connect a StreamLayer with a custom websocket server (built with NodeJS) and it's working in JS API 3.x & 4.x except in versions >= 4.9. We noticed in this version (4.9) the StreamLayer was updated, so we guess something might be broken because to our understanding the changes shouldn't affect to the behaviour of this example.
I have recorded a video to show you the issue:
Does anyone have any idea what might be going on? In case you look the source code you can find it on this repo on Github. // cc: John Grayson John Gravois Gavin Rehkemper Sean McGeeMax PaysonRene Rubalcava ‌
By the way..., sorry for not been at the DevSummit in Palm Springs! :___(, hopefully we'll see some of you at the DevSummit Europe this year!
mgeorge
Hi Axelle Ribault‌,
In 4.11 we don't yet have support for passing in user-specified WebSocket connections, but you can use GeoEvent server to create a Stream Service.
Raul_Jimenez
Hi Axelle Ribault‌ it is possible to create a custom Stream Service, you can download the one we mentioned before.
Cheers
AxelleRibault
Impressive, thank you for your work.
Raul_Jimenez
Finally Jorge Barrachina Gutiérrez fixed the issue we had, you can see how on this commit.
So feel free to download the code: https://github.com/esri-es/arcgis_websocket_server
FYI: We are still working on the "develop" branch.
Thanks Jorge, you rules!
