CSS not properly loading, buttons & widget not rendering correctly
1549
6
09-02-2021 08:21 AM
KevinWrona
New Contributor II
Hey,
I am using ArcGIS API for JavaScript 4.20 ES modules and I am trying to add a Sketch Widget to the top right corner. The standard buttons like Zoom in and Zoom out and the widget are not rendering properly. All I am getting is the following:
Like in the documentation i am adding CSS resource with @import "@arcgis/core/assets/esri/themes/light/main.css";
Nearly the same Code worked with 4.17.
My angular component below.
import MapView from '@arcgis/core/views/MapView';
import BaseMap from '@arcgis/core/Basemap';
import WMSLayer from "@arcgis/core/layers/WMSLayer";
import Map from "@arcgis/core/Map";
import esriConfig from "@arcgis/core/config";
import Sketch from "@arcgis/core/widgets/Sketch";
import GraphicsLayer from "@arcgis/core/layers/GraphicsLayer";
@Injectable()
export class AppComponent{
  // The <div> where we will place the map
  @ViewChild('mapViewNode', { static: true }) private mapViewEl: ElementRef | undefined;
  constructor() {
    esriConfig.assetsPath = "assets/@arcgis/core/assets";
  public initializeMap() {
    const graphicsLayer = new GraphicsLayer();
    const basemap = new BaseMap({
      baseLayers: [
        new WMSLayer({
          url: '<URL to WMS Server>?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities'
    const map = new Map({
      basemap: basemap,
      layers: [graphicsLayer]
    const view = new MapView({
      container: this.mapViewEl?.nativeElement,
      map: map,
      zoom: 5,
      center: [90, 45]
    view.when(() => {
      const sketch = new Sketch({
        layer: graphicsLayer,
        view: view
      view.ui.add(sketch, "top-right");
  public ngOnInit(): void {
    // Initialize MapView and return an instance of MapView
    this.initializeMap();
Any ideas?
ReneRubalcava
What does you build set up look like? Are you using webpack or some other framework build?
KevinWrona
New Contributor II
Thanks for quick answer! Only installed ArcGIS JS API with npm ang run my angular app with "ng serve" ...
AndyGup
Hi Kevin, I'm not sure I understand, we didn't have ES modules (@arcgis/core) at 4.17. Is there a reason why you want to host the assets locally? They'll automatically pull from CDN, here's some additional info: https://developers.arcgis.com/javascript/latest/es-modules/#working-with-assets
KevinWrona
New Contributor II
Hi Andy, at 4.17 it worked with AMD and for 4.20 I used ES modules, so only import statements and assets changed, core code is the same. I am in a security environment with no internet connection and own GIS Server. After copying the assets there are no exceptions or warnings so i have no clue why the rendering not like in 4.17
AndyGup
Okay, that's kind of what I figured, thanks for clarifying. It is odd that there are no 404, or even 504, errors when the app tries to retrieve the assets. One likely possibility is your assetsPath setting, the example above isn't what I would expect to see. Have you tried something like this:
esriConfig.assetsPath = "./assets";
If that doesn't work, send us a snippet of how you are copying the assets, such as your npm script, etc.
KevinWrona
New Contributor II
I tried in 2 seperate projects. In one project I use the:
"copyEsriAssets": "xcopy .\\node_modules\\@arcgis\\core\\assets .\\apps\\vwa\\src\\assets\\@arcgis\\core\\assets /sy"
In a second blank Angular project for testing I copied the assets (esri and components folder) manually to my-app\src\assets\@arcgis\core\assets and use
esriConfig.assetsPath = "./assets/@arcgis/core/assets";
I am sure the path is correct becauce if I change it I get a 404 for widget-assets not found and so on ...
So I am not sure about what is important next to the asset folder and the import of main.css
