Change point styles in Api for JavaScript - web apps
2503
03-14-2021 03:18 PM
EdissonGabrielLópezSalamanca
Hello ESRI community,
I need help with a problem I am having using the ArcGIS API for JavaScript - v18. Well the problem is that I want to try to change the points that comes from a cycle-parking API by some images depending on the parking if it is "GOLD" or "SILVER" should place the image that corresponds to it with respect to the VALUE. Then as I am doing it it does not render me the points that I need to change by the images or it shows me the error, my code is the following one:
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1, user-scalable=no"
    <title>Prueba - ArcGIS API for JavaScript</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #titleDiv {
        position: absolute;
        height: 55px;
        width: 100%;
        display: flex;
        justify-content: space-between;
        color: #f8f8f8;
        background: #464646;
        z-index: 1;
      #title {
        margin: 15px;
        font-size: 20px;
        overflow: hidden;
      .invisible {
        visibility: collapse;
      .esri-expand .esri-expand__content {
        box-shadow: none;
      .esri-view-height-xsmall .esri-ui-corner .esri-expand .esri-legend.esri-widget,
      .esri-view-height-small .esri-ui-corner .esri-expand .esri-legend.esri-widget {
        max-height: 100%;
      .esri-view-width-less-than-small .esri-zoom .esri-widget--button {
        display: none;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.18/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.18/"></script>
    <script>
      require([
        "esri/config",
        "esri/Map",
        "esri/views/MapView",
        "esri/widgets/Expand",
        "esri/widgets/Directions",
        "esri/layers/FeatureLayer",
        "dojo/domReady!",
      ], function (esriConfig, Map, MapView, Expand ,Directions,FeatureLayer ) {
        esriConfig.apiKey =
          "AAPKe5cbac65965142caacc4f99e879243a96wQMcjhjr_Mm6589Qkt56_B-AOFWPshBSJKcBcVTLMojNCQSboxBogAduxYsvrDY";
        var map = new Map({
          basemap: "topo-vector",
        var view = new MapView({
          title: document.getElementById("title").innerHTML = "Cicloparqueaderos Certificados Bogota D.C",
          container: "viewDiv",
          map: map,
          center: [-74.093, 4.637],
          zoom: 12,
        //Image gold
        const goldImg = {
          type: "picture-marker",
          url: "https://i.ibb.co/5YggNTj/oro.png"
        //Image Silver
        const silverImg = {
          url: "https://i.ibb.co/SQhxKHT/plata.png"
        var pointsRenderer = {
        type: "unique-value",
            uniqueValueInfos: [
                value: "1",
                symbol: goldImg
                value: "2",
                symbol: silverImg
        var trailheadsLayer = new FeatureLayer({
          url:
            "https://services2.arcgis.com/NEwhEo9GGSHXcRXV/arcgis/rest/services/Cicloparqueaderos_Certificados_Bogota_D_C/FeatureServer/0",
            //Render
            renderer: pointsRenderer,
            outFields: ["*"],
          popupTemplate: {
            title: "Cicloparqueaderos Certificados Bogota D.C {COD_CICP}",
            content: [
                type: "fields", // FieldsContentElement
                fieldInfos: [
                    fieldName: "COD_CICP",
                    visible: true,
                    label: "Codigo_Cicloparqueadero",
                    fieldName: "NOMBRE_CICP",
                    visible: true,
                    label: "Nombre_Cicloparqueadero",
                    fieldName: "HORARIO_CICP",
                    visible: true,
                    label: "Horario_CicP",
                    fieldName: "DIRECCION",
                    visible: true,
                    label: "DIRECCION",
                    fieldName: "LOCALIDAD",
                    visible: true,
                    label: "LOCALIDAD",
                    fieldName: "CUPOS",
                    visible: true,
                    label: "Cupos_Bici",
                    fieldName: "TIPOLOGIA_CICP",
                    visible: true,
                    label: "Tipologia_Cicloparqueadero",
                    fieldName: "SELLO",
                    visible: true,
                    label: "SELLO_TIPO",
        map.add(trailheadsLayer);
        var directionsWidget = new Directions({
          view: view,
          // Apunte la URL a un servicio de ruta válido que utilice un
          // Proxy de servicio alojado de ArcGIS Online en lugar del servicio predeterminado
          routeServiceUrl:
            "https://utility.arcgis.com/usrsvcs/appservices/srsKxBIxJZB0pTZ0/rest/services/World/Route/NAServer/Route_World",
          container: document.createElement("div")
        var directionsExpand = new Expand({
        view: view,
        content: new Directions({
            view: view,
            routeServiceUrl:
        // Load
        isResponsiveSize = view.widthBreakpoint === "xsmall";
        updateView(isResponsiveSize);
        // Breakpoints
        view.watch("widthBreakpoint", function(breakpoint) {
          switch (breakpoint) {
            case "xsmall":
              updateView(true);
              break;
            case "small":
            case "medium":
            case "large":
            case "xlarge":
              updateView(false);
              break;
            default:
        function updateView(isMobile) {
          setTitleMobile(isMobile);
          setLegendMobile(isMobile);
        function setTitleMobile(isMobile) {
          if (isMobile) {
            document.querySelector("#titleDiv").classList.add("invisible");
            view.padding = {
              top: 0
          } else {
            document.querySelector("#titleDiv").classList.remove("invisible");
            view.padding = {
              top: 55
        function setLegendMobile(isMobile) {
          var toAdd = isMobile ? directionsExpand : directionsWidget;
          var toRemove = isMobile ? directionsWidget : directionsExpand;
          view.ui.remove(toRemove);
          view.ui.add(toAdd, "top-right");
        // Agrega el widget Indicaciones en la esquina superior derecha de la vista
        // view.ui.add(directionsExpand, {
        //   position: "top-right",
    </script>
  </head>
  <body>
    <div id="titleDiv" class="esri-widget"><div id="title"></div></div>
    <div id="viewDiv"></div>
    <div id="instruction" class="esri-widget">
      Haga clic en cualquier ubicación en el mapa para ver su dirección postal
    </div>
  </body>
</html>
The points I want to change for the images are these:
link api (https://services2.arcgis.com/NEwhEo9GGSHXcRXV/arcgis/rest/services/Cicloparqueaderos_Certificados_Bo...?)
I hope you can help me, thank you.
KenBuja
MVP Esteemed Contributor
In your renderer, you didn't indicate what field you wanted to apply the unique value renderer.
 field: "Sello", //this was left out
 uniqueValueInfos: [
     value: "1",
     symbol: goldImg
     value: "2",
     symbol: silverImg
KenBuja
 uniqueValueInfos: [
     value: "1",
     symbol: goldImg
     value: "2",
     symbol: silverImg
