Buttons in calcite nav to open panels widgets like the dropdown
2577
05-22-2019 05:49 AM
KennethLindhardt1
Hi, I hope you can help. I need the buttons from the dropdown, controlling the widgets moved out in the calcite-navbar, like the picture, and they need to work :-):
The  "Full map " are working, but that are not controlling the widgets, the basemap button don't do anything
Although it has the same lines as the links in the drop-down.
I’m trying on this example: https://developers.arcgis.com/javascript/latest/sample-code/frameworks-bootstrap/index.html
<nav
class="navbar calcite-navbar navbar-fixed-top calcite-text-light calcite-bg-dark"
<!-- Menu -->
<div
class="dropdown calcite-dropdown calcite-text-dark calcite-bg-light"
role="presentation"
<a
class="dropdown-toggle"
role="button"
aria-haspopup="true"
aria-expanded="false"
<div class="calcite-dropdown-toggle">
<span class="sr-only">Toggle dropdown menu</span> <span></span>
<span></span> <span></span> <span></span>
</div>
</a>
<ul class="dropdown-menu">
<li class="active">
<a
class="hidden-md hidden-lg"
href="#mapTab"
aria-controls="mapTab"
role="tab"
data-toggle="tab"
Map</a
</li>
<li>
<a
href="#sceneTab"
aria-controls="sceneTab"
role="tab"
data-toggle="tab"
Scene</a
</li>
<!-- Copied/Paste From Here: -->
<li>
<a role="button" data-target="#panelBasemaps" aria-haspopup="true"
><span class="glyphicon glyphicon-th-large"></span> Basemaps</a
</li>
<li>
<a role="button" data-target="#panelSettings" aria-haspopup="true"
><span class="glyphicon glyphicon-cog"></span> Settings</a
</li>
<li>
<a role="button" id="calciteToggleNavbar" aria-haspopup="true"
><span class="glyphicon glyphicon-fullscreen"></span> Full Map</a
</li>
<!-- To Here -->
</ul>
</div>
<!-- Title -->
<div class="calcite-title calcite-overflow-hidden">
<span class="calcite-title-main">Calcite Maps</span>
<span class="calcite-title-divider hidden-xs"></span>
<span class="calcite-title-sub hidden-xs"
>A modern framework for building map apps</span
</div>
<!-- Nav -->
<ul class="nav navbar-nav calcite-nav">
<li class="active">
<a
id="mapNav"
class="hidden-xs hidden-sm"
href="#mapTab"
aria-expanded="true"
role="tab"
data-toggle="tab"
data-tooltip="tip"
title="2D View"
data-placement="bottom"
>Map</a
</li>
<li>
<a
id="sceneNav"
href="#sceneTab"
role="tab"
data-toggle="tab"
data-tooltip="tip"
title="3D View"
>Scene</a
</li>
<li>
<div class="calcite-navbar-search calcite-search-expander">
<div id="searchWidgetDiv"></div>
</div>
</li>
<li>
</li>
<li>
</li>
</ul>
</nav>
And then it has to open this panel
<div id="panelSettings" class="panel panel-map collapse">
<div id="headingSettings" class="panel-heading">
<div class="panel-title">
<a
class="panel-toggle"
role="button"
data-toggle="collapse"
href="#collapseSettings"
data-parent="#panelAccordion"
aria-controls="collapseSettings"
><span class="glyphicon glyphicon-cog" aria-hidden="true"></span
><span class="panel-label">Settings</span></a
<a
class="panel-close"
role="button"
><span class="esri-icon esri-icon-close" aria-hidden="true"></span
></a>
</div>
</div>
Hope it make sense 🙂
Thanks.
RobertScheitlin__GISP
Kenneth,
   Here is what I have working:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="width=device-width,initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Calcite Maps and Bootstrap - 4.11</title>
    <!-- Calcite Bootstrap -->
    <link
      rel="stylesheet"
      href="https://esri.github.io/calcite-maps/dist/css/calcite-maps-bootstrap.min-v0.8.css"
    <!-- Calcite Maps -->
    <link
      rel="stylesheet"
      href="https://esri.github.io/calcite-maps/dist/css/calcite-maps-arcgis-4.x.min-v0.8.css"
    <!-- ArcGIS JS 4 -->
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.11/esri/themes/light/main.css"
    <style>
      html,
      body {
        margin: 0;
        padding: 0;
        height: 100%;
    </style>
  </head>
  <body class="calcite-maps calcite-nav-top">
    <!-- Navbar -->
    <nav
      <!-- Menu -->
      <div
        role="presentation"
        <a
          role="button"
          </div>
        </a>
          <li class="active">
            <a
              href="#mapTab"
              role="tab"
              data-toggle="tab"
              Map</a
          </li>
          <li>
            <a
              href="#sceneTab"
              role="tab"
              data-toggle="tab"
              Scene</a
          </li>
          <li>
          </li>
          <li>
          </li>
          <li>
          </li>
        </ul>
      </div>
      <!-- Title -->
      </div>
      <!-- Nav -->
        <li class="active">
          <a
            id="mapNav"
            href="#mapTab"
            role="tab"
            data-toggle="tab"
            data-tooltip="tip"
            title="2D View"
            >Map</a
        </li>
        <li>
          <a
            id="sceneNav"
            href="#sceneTab"
            role="tab"
            data-toggle="tab"
            data-tooltip="tip"
            title="3D View"
            >Scene</a
        </li>
        <li>
          </div>
        </li>
        <li>
          <a role="button" id="showBasemaps" aria-haspopup="true"
        </li>
        <li>
        </li>
      </ul>
    </nav>
    <!--/.calcite-navbar -->
    <!-- Map  -->
    <div class="calcite-map calcite-map-absolute">
      <div id="tabContainer" class="tab-content">
        <div id="mapTab" class="tab-pane fade in active" role="tabpanel">
          <div id="mapViewDiv"></div>
        </div>
        <div id="sceneTab" class="tab-pane fade" role="tabpanel">
          <div id="sceneViewDiv"></div>
        </div>
      </div>
    </div>
    <!-- /.calcite-map -->
    <!-- Panels -->
    <div
      class="calcite-panels calcite-panels-right calcite-text-light calcite-bg-dark panel-group"
      <!-- Basemaps Panel -->
      <div id="panelBasemaps" class="panel collapse">
        <div id="headingBasemaps" class="panel-heading" role="tab">
            <a
              class="panel-toggle collapsed"
              role="button"
              href="#collapseBasemaps"
              aria-controls="collapseBasemaps"
              ><span
                aria-hidden="true"
              ></span
              ><span class="panel-label">Basemaps</span></a
            <a
              class="panel-close"
              role="button"
            ></a>
          </div>
        </div>
        <div
          id="collapseBasemaps"
          class="panel-collapse collapse"
          role="tabpanel"
          aria-labelledby="headingBasemaps"
          <div class="panel-body"><div id="basemapPanelDiv"></div></div>
        </div>
      </div>
      <!-- Panel Settings -->
            <a
              role="button"
            <a
              class="panel-close"
              role="button"
            ></a>
          </div>
        </div>
        <div
          id="collapseSettings"
          role="tabpanel"
          aria-labelledby="headingSettings"
            <div class="form-horizontal">
              <!-- Theme -->
              <div class="form-group">
                <label for="settingsTheme" class="col-xs-3 control-label"
                  >Theme</label
                <div class="col-xs-9">
                  <select id="settingsTheme" class="form-control">
                    <option
                      value="calcite-dark"
                      data-textcolor="calcite-text-light"
                      data-bgcolor="calcite-bg-dark"
                      selected
                      >Calcite Dark</option
                    <option
                      value="calcite-light"
                      data-textcolor="calcite-text-dark"
                      data-bgcolor="calcite-bg-light"
                      >Calcte Light</option
                  </select>
                </div>
              </div>
              <!-- Color -->
                <label for="settingsColor" class="col-xs-3 control-label"
                  >Color</label
                  <select id="settingsColor" class="form-control">
                    <option value="" data-theme="calcite-theme-light"
                      >Calcite Default</option
                    <option
                      value="calcite-bgcolor-dark-blue"
                      data-bgcolor="calcite-bg-custom"
                      >Calcite Dark Blue</option
                    <option
                      value="calcite-bgcolor-dark-green"
                      >Calcite Dark Green</option
                    <option
                      value="calcite-bgcolor-dark-brown"
                      >Calcite Dark Brown
                    </option>
                    <option
                      value="calcite-bgcolor-dark-red"
                      >Calcite Dark Red</option
                    <option
                      value="calcite-bgcolor-darkest-grey"
                      >Calcite Darkest Grey</option
                    <option
                      value="calcite-bgcolor-lightest-grey"
                      >Calcite Lightest Grey</option
                    <option
                      value="calcite-bgcolor-blue-75"
                      >Calcite Blue 75%</option
                    <option
                      value="calcite-bgcolor-black-75"
                      >Calcite Black 75%</option
                  </select>
                </div>
              </div>
              <!-- Widgets -->
                <label for="settingsWidgets" class="col-xs-3 control-label"
                  >Widgets</label
                  <select id="settingsWidgets" class="form-control">
                    <option value="calcite-widgets-dark">Calcite Dark</option>
                    <option value="calcite-widgets-light" selected
                      >Calcite Light</option
                  </select>
                </div>
              </div>
              <!-- Layout -->
                <label for="settingsLayout" class="col-xs-3 control-label"
                  >Layout</label
                  <select id="settingsLayout" class="form-control">
                    <option
                      value="calcite-nav-top"
                      data-nav="navbar-fixed-top"
                      selected
                      >Top</option
                    <option
                      value="calcite-nav-bottom"
                      data-nav="navbar-fixed-bottom"
                      >Bottom</option
                  </select>
                </div>
              </div>
            </div>
          </div>
        </div>
      </div>
    </div>
    <!-- /.calcite-panels -->
    <script type="text/javascript">
      var dojoConfig = {
        packages: [
              "https://esri.github.io/calcite-maps/dist/vendor/dojo-bootstrap"
            location: "https://esri.github.io/calcite-maps/dist/js/dojo"
    </script>
    <script src="https://js.arcgis.com/4.11/"></script>
    <script>
      var app;
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/views/SceneView",
        "esri/widgets/Search",
        "esri/widgets/BasemapGallery",
        "esri/core/watchUtils",
        "dojo/query",
        // Calcite Maps
        "calcite-maps/calcitemaps-v0.8",
        // Calcite Maps ArcGIS Support
        "calcite-maps/calcitemaps-arcgis-support-v0.8",
        // Bootstrap
        "bootstrap/Collapse",
        "bootstrap/Dropdown",
        "bootstrap/Tab",
        // Can use @dojo shim for Array.from for IE11
        "@dojo/framework/shim/array"
      ], function(
        Map,
        MapView,
        SceneView,
        Search,
        Basemaps,
        watchUtils,
        query,
        CalciteMaps,
        CalciteMapsArcGIS
         * App settings
        app = {
          center: [-40, 40],
          scale: 50000000,
          basemap: "streets",
          viewPadding: {
            top: 50,
            bottom: 0
          uiComponents: ["zoom", "compass", "attribution"],
          mapView: null,
          sceneView: null,
          containerMap: "mapViewDiv",
          containerScene: "sceneViewDiv",
          activeView: null,
          searchWidget: null
         * Create the map and scene view and ui components
        // Map
        const map = new Map({
          basemap: app.basemap
        // 2D view
        app.mapView = new MapView({
          container: app.containerMap,
          map: map,
          center: app.center,
          scale: app.scale,
          padding: app.viewPadding,
          ui: {
            components: app.uiComponents
        CalciteMapsArcGIS.setPopupPanelSync(app.mapView);
        // 3D view
        app.sceneView = new SceneView({
          container: app.containerScene,
          map: map,
          center: app.center,
          scale: app.scale,
          ui: {
        CalciteMapsArcGIS.setPopupPanelSync(app.sceneView);
        // Set the active view to scene
        setActiveView(app.mapView);
        // Create the search widget and add it to the navbar instead of view
        app.searchWidget = new Search(
            view: app.activeView
          "searchWidgetDiv"
        CalciteMapsArcGIS.setSearchExpandEvents(app.searchWidget);
        // Create basemap widget
        app.basemapWidget = new Basemaps({
          view: app.activeView,
          container: "basemapPanelDiv"
         * Synchronize the view, search and popup
        // Views
        function setActiveView(view) {
          app.activeView = view;
        function syncViews(fromView, toView) {
          const viewPt = fromView.viewpoint.clone();
          fromView.container = null;
          if (fromView.type === "3d") {
            toView.container = app.containerMap;
          } else {
            toView.container = app.containerScene;
          toView.padding = app.viewPadding;
          toView.viewpoint = viewPt;
        document.getElementById('showBasemaps').addEventListener("click",
        function(event) {
          query('#panelBasemaps').collapse("show");
        // Search Widget
        function syncSearch(view) {
          watchUtils.whenTrueOnce(view, "ready", function() {
            app.searchWidget.view = view;
            if (app.searchWidget.selectedResult) {
              app.searchWidget.search(app.searchWidget.selectedResult.name);
        // Tab - toggle between map and scene view
        const tabs = Array.from(
          document.querySelectorAll(".calcite-navbar li a[data-toggle='tab']")
        tabs.forEach(function(tab) {
          tab.addEventListener("click", function(event) {
            if (event.target.text.indexOf("Map") > -1) {
              syncViews(app.sceneView, app.mapView);
            } else {
              syncViews(app.mapView, app.sceneView);
              setActiveView(app.sceneView);
            syncSearch(app.activeView);
         * Apply Calcite Maps CSS classes to change application on the fly
         * For more information about the CSS styles or Sass build visit:
         * http://github.com/esri/calcite-maps
        const cssSelectorUi = [
          document.querySelector(".calcite-navbar"),
          document.querySelector(".calcite-panels")
        const cssSelectorMap = document.querySelector(".calcite-map");
        // Theme - light (default) or dark theme
        const settingsTheme = document.getElementById("settingsTheme");
        const settingsColor = document.getElementById("settingsColor");
        settingsTheme.addEventListener("change", function(event) {
          const textColor =
            event.target.options[event.target.selectedIndex].dataset.textcolor;
          const bgColor =
            event.target.options[event.target.selectedIndex].dataset.bgcolor;
          cssSelectorUi.forEach(function(element) {
            element.classList.remove(
              "calcite-text-dark",
              "calcite-text-light",
              "calcite-bg-dark",
              "calcite-bg-light",
              "calcite-bg-custom"
            element.classList.add(textColor, bgColor);
              "calcite-bgcolor-dark-blue",
              "calcite-bgcolor-blue-75",
              "calcite-bgcolor-dark-green",
              "calcite-bgcolor-dark-brown",
              "calcite-bgcolor-darkest-grey",
              "calcite-bgcolor-lightest-grey",
              "calcite-bgcolor-black-75",
            element.classList.add(bgColor);
          settingsColor.value = "";
        // Color - custom color
        settingsColor.addEventListener("change", function(event) {
          const customColor = event.target.value;
          const textColor =
          const bgColor =
              "calcite-bg-dark",
              "calcite-bg-light",
              "calcite-bg-custom"
            element.classList.add(customColor);
            if (!customColor) {
              settingsTheme.dispatchEvent(new Event("change"));
        // Widgets - light (default) or dark theme
        const settingsWidgets = document.getElementById("settingsWidgets");
        settingsWidgets.addEventListener("change", function(event) {
          const theme = event.target.value;
          cssSelectorMap.classList.remove(
            "calcite-widgets-dark",
          cssSelectorMap.classList.add(theme);
        // Layout - top or bottom nav position
        const settingsLayout = document.getElementById("settingsLayout");
        settingsLayout.addEventListener("change", function(event) {
          const layout = event.target.value;
          const layoutNav =
            event.target.options[event.target.selectedIndex].dataset.nav;
          document.body.classList.remove(
            "calcite-nav-bottom",
            "calcite-nav-top"
          document.body.classList.add(layout);
          const nav = document.querySelector("nav");
          nav.classList.remove("navbar-fixed-bottom", "navbar-fixed-top");
          nav.classList.add(layoutNav);
          setViewPadding(layout);
        // Set view padding for widgets based on navbar position
        function setViewPadding(layout) {
          let padding, uiPadding;
          // Top
          if (layout === "calcite-nav-top") {
            padding = {
              padding: {
                top: 50,
                bottom: 0
            uiPadding = {
              padding: {
                top: 15,
                right: 15,
                bottom: 30,
                left: 15
          } else {
            // Bottom
            padding = {
              padding: {
                top: 0,
                bottom: 50
            uiPadding = {
              padding: {
                top: 30,
                right: 15,
                bottom: 15,
                left: 15
          app.mapView.set(padding);
          app.mapView.ui.set(uiPadding);
          app.sceneView.set(padding);
          app.sceneView.ui.set(uiPadding);
          // Reset popup
          if (
            app.activeView.popup.visible &&
            app.activeView.popup.dockEnabled
            app.activeView.popup.visible = false;
            app.activeView.popup.visible = true;
    </script>
  </body>
</html>
MuratKORUYUCU
Dear RobertScheitlin__GISP,
Can you add buttons for openning LayerList, Legend and Info in Calcite navbar? I want to remove dropdown menu and use only these buttons. And I am new for webmap design. Thank you...
