applyEdits not working
3450
6
01-13-2021 03:20 PM
RabinSubedi
Hello Everyone!
I am trying to update the existing value of "PCR_NBR" in featurelayer by looking at the sample code of ArcGIS API for JS using apply edits, but its not working. In this code I am just trying to replace the value by 20. Also is it possible to run loop to have conditional statement, for eg: if PCR_NBR is less than 50, replace it by 20, if it is more than 50, replace it by 100?
Thanks in advance!
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>
      Update Feature Attributes | Sample | ArcGIS API for JavaScript 4.18
    </title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.18/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.18/"></script>
    <style>
      html,
      body,
      #viewDiv {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      #info {
        padding: 14px;
        border-radius: 5px;
      #update {
        padding: 6px;
      #form {
        background: #fff;
      /* replaces esri-widget--panel */
      .scroller {
        overflow-x: hidden;
        overflow-y: auto;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/widgets/FeatureForm",
        "esri/layers/FeatureLayer",
        "esri/form/FormTemplate"
      ], function(Map, MapView, FeatureForm, FeatureLayer, FormTemplate) {
        let highlight, editFeature;
        var popupMajorRoads = {
          title: "Pavement Condition Rating(PCR): " + "{PCR_NBR}",
          content: [{
            type: "fields",
            fieldInfos: [{
                fieldName: "PCR_YEAR",
                label: "PCR Year",
                isEditable: true,
                tooltip: "",
                visible: true,
                format: null,
                stringFieldOption: "text-box"
                fieldName: "PCR_NBR",
                label: "Pavement Condition (PCR)",
                isEditable: true,
                tooltip: "",
                visible: true,
                format: null,
                fieldName: "NLFID",
                label: "NLFID",
                isEditable: true,
                tooltip: "",
                visible: true,
                format: null,
                fieldName: "JURISDICTI",
                label: "Juristiction",
                isEditable: true,
                tooltip: "",
                visible: true,
                format: null,
                fieldName: "ROUTE_TYPE",
                label: "Route Type",
                isEditable: true,
                tooltip: "",
                visible: true,
                format: null,
                fieldName: "ROUTE_NBR",
                label: "Route Number",
                isEditable: true,
                tooltip: "",
                visible: true,
                format: null,
                fieldName: "DIRECTION_",
                label: "Direction",
                isEditable: true,
                tooltip: "",
                visible: true,
                format: null,
                fieldName: "LANES",
                label: "Number of Lanes",
                isEditable: true,
                tooltip: "",
                visible: true,
                format: null,
        const featureLayer = new FeatureLayer({
          portalItem: {
          outFields: ["*"],
          visible: true,
          popupTemplate: popupMajorRoads
        const map = new Map({
          basemap: "topo-vector",
          layers: [featureLayer]
        let view = new MapView({
          map: map,
          container: "viewDiv",
          center: [-82.9988, 39.9612],
          zoom: 10,
        featureLayer.queryFeatures({
            outFields: ["*"],
            returnGeometry: true
          .then(function(results) {
            if (results.features.length > 0) {
              editFeature = results.features[0];
              editFeature.attributes.PCR_NBR = 20;
        const edits = {
          updateFeatures: [editFeature]
        featureLayer.applyEdits(edits);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
    <div id="info" class="esri-widget">
    </div>
  </body>
</html>
KenBuja
MVP Esteemed Contributor
As for doing it in a loop, try this (untested).
editFeatures = results.features;
editFeatures.forEach(editFeature => {
  if (editFeature.attributes.PCR_NBR < 50) {
  } else {
    editFeature.attributes.PCR_NBR = 100;
const edits = {
  updateFeatures: editFeatures
BlakeTerhune
MVP Regular Contributor
Starting with the simplest things, have you verified the PortalItem is hosted as a Feature Service with Update capabilities? Are you getting an error in the console?
RabinSubedi
@BlakeTerhuneThanks for your reply. I am not sure if I understood your question properly or not. I just uploaded a shapefile to arcgis for developers and got portalid from there. I didn't add any additional settings to it. Also, I don't want this code to make changes to the original data in server, I just want to make temporary change on workspace only.
BlakeTerhune
No worries. Looks like you were able to get to the root of the problem. Carry on!
KenBuja
You are calling applyEdits outside the queryFeatures function, meaning it's trying to apply the edits before the query is finished. Try moving it inside the "then" function
  outFields: ["*"],
    const edits = {
KenBuja
  } else {
const edits = {
RabinSubedi
Thank you very much @KenBuja, it works. One more question: once we update the attribute value, shouldn't the value in popup window update by itself? Also the value in featuretable widget (assuming we have it in this code)?
