I can create the menu item but am stumped how I add the menu item to the FeatureTable's menu. Any suggestions would be great.
This has worked for me on JS API 4.23:
const table = new FeatureTable({ layer: myLayer, fieldConfigs: myFields, attachmentsEnabled: false, visibleElements: { selectionColumn: true, header: true, menu: true } }); table.when().then(() => { const newMenuItem = { label: "Do something", clickFunction: (event) => { console.log("Clicked!"); } }; table.menu.items.push(newMenuItem); });
Yes, thank you. I think I was passing the wrong object to the menu.
Update - it worked inconsistently but doesn't seem to be working at all now.
add visible property on object newMenuItem
table.when().then(() => { const newMenuItem = { label: "Do something", iconClass: "Icon font name, if applicable", visible: true, clickFunction: (event) => { console.log("Clicked!"); } }; table.menu.items.push(newMenuItem); });
The menu property is marked as readonly and should not be edited. You can use the property menuConfig instead. Here is an example which shows standard entries and a custom menu item in the Feature Tables's menu
featureTable.when().then(() => { const buttonMenuItem1 = new ButtonMenuItem ({ label: "custom menu item label", clickFunction: function () { console.log("click MenuItem1"); } }); const buttonMenu = new ButtonMenu ({ iconClass: "esri-icon-handle-horizontal", items: [] }); featureTable.menu.items.forEach(element => { buttonMenu.items.push(element); }); buttonMenu.items.push(buttonMenuItem1); featureTable.menuConfig = buttonMenu; });
