Add a Second Pane to Left Side
1591
9
11-07-2014 06:09 AM
ChrisHolmes
Hello all,
I have a javascript application that uses the following CSS/HTML to create the displayed output:
#leftPane {
     margin:5px; /*added this, seems to align #leftPane & #map a bit nicer*/
     width:200px; /*300px;*/
     color:#3C1700;
     background-color:#FFF;
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" class="roundedCorners" id="leftPane">
     <div>Click the pin below then click location on map to add your comment.</div>
     <div id="templatePickerDiv"></div>
</div>
I would like to add a pane to the lower left area, so that it will look like the below picture but am having difficulty figuring out how to change the code. I had read something about having to nest the panes but haven't figured anything out. Any help appreciated! Thanks
JakeSkinner
Esri Esteemed Contributor
Here is the html you could use:
   <div id="legend"></div>
</div>
Here is the CSS:
#leftPane {
    width:300px;
    color:#3C1700;
#templatePickerDiv{
    border-style:solid;
    border-color: #3C1700;
    height: 49%;
.templatePicker {
    height: 49% !important;
#legend{
    margin-top:5px;
    border-style:solid;
    border-width:thin;
    height: 49%;
ChrisHolmes
For some reason the HTML didn't paste in above:
</div>
TimWitt2
Chris,
here is an example of 2 panes:
ArcGIS API for JavaScript Sandbox
Tim
TimWitt2
Ohh never mind, my example doesn't solve your issue. Let me see if I can post something else.
ChrisHolmes
Thanks for your time Tim, appreciated!
JakeSkinner
</div>
Here is the CSS:
#leftPane {
    width:300px;
    color:#3C1700;
#templatePickerDiv{
    border-style:solid;
    height: 49%;
.templatePicker {
#legend{
    margin-top:5px;
    border-style:solid;
    border-width:thin;
    height: 49%;
ChrisHolmes
Hi Jake, thanks for the reply. I’m just playing around with this now. Will let you know how it goes.
Chris
ChrisHolmes
I now have it looking as below. What I find interesting is if I try to move the text "Click the pin..." into the div with the add comment pin, for example I tried this: <div id="templatePickerDiv>abc</div>. When the page renders the "abc" is drawn underneath the "Add Comment".
Can you tell me:
1. what is the significance of !important
2. As far as design goes, what's best? I currently have 2 div's within a left pane. It looks ok, I guess, but is there a better way I should look at doing this?
Chris
JakeSkinner
1.  Take a look at the following link.
What does !important mean in CSS?
2.  A personal preference of mine is to use an AccordionContainer.  See the following example:
Map container split in three | ArcGIS API for JavaScript
ChrisHolmes
Thanks Jake, I’m going to look into the AccordionContainer, it’s a nice looking layout.
