Accessor#set Assigning an instance of 'esri.Graphic' which is not a subclass of 'esri.Graphic'
3496
5
04-12-2021 06:23 PM
LaurynasGedminas2
import Graphic from '@arcgis/core/Graphic';
import Point from '@arcgis/core/geometry/Point';
import SimpleMarkerSymbol from '@arcgis/core/symbols/SimpleMarkerSymbol';
	componentDidUpdate (props) {
		console.log(props);
		const Point ={
			type: "point",
			longitude: props.data[23],
			latitude: props.data[24]
		const simpleMarkerSymbol = {
			type: "simple-marker",
			color: [46, 204, 113 ],  // Green
			outline: {
			color: [255, 255, 255], // white
			width: 1
		const pointGraphic = new Graphic({
			geometry: Point,
			symbol: simpleMarkerSymbol
			//attributes: attributes,
			//popupTemplate: popupTemplate
		const graphicB = new Graphic({  // graphic with point geometry
			geometry: new Point({
				type: "point",
			}), // set geometry here
			symbol: new SimpleMarkerSymbol({
				outline: {
					width: 1}
				// set symbol here
		this.props.view.graphics.add(pointGraphic);
error:
Tags (1)
JohnGrayson
Esri Alum
You import the class Point and then redefine this variable in your code to an object instance.  Try these changes:
const myPoint ={
  type: "point",
  geometry: myPoint,
LaurynasGedminas2
Still gettign the error:
[esri.core.Accessor] Accessor#set Assigning an instance of 'esri.Graphic' which is not a subclass of 'esri.Graphic'
		console.log(props);
		const myPoint ={
			type: "point",
			longitude: props.data[24],
			latitude: props.data[23]
			outline: {
			width: 1
			geometry: myPoint,
				type: "point",
				outline: {
					width: 1}
JohnGrayson
Esri Alum
Do you have a simple CodePen showing the issue?
LaurynasGedminas2
Hey,
Do you have an exmaple of the ESRI JS API import in CodePen?
Thank you,
ŁukaszWiszniewski
I occurred the same issue. Where I add an instance of SimpleMarkerSymbol. It is visible on the map but console shows the same error. I use JSAPI 4.30 with Expereience Builder. Does anyone has solved this?
