support of "htmlPopup" in the FlexAPI
878
08-18-2010 09:25 PM
TomSchuller
Hy,
I want to ask if the "htmlPopup" from the RestAPI is supported in the ArcGIS FlexApi 2.0.
How can I use it?
Here is an example of the rest-htmlpopup:
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/StantonCountyKSLeases/MapServer...
Tom
DasaPaddock
The only support is in the LayerDetails which as a htmlPopupType property to know if the layer supports popups or not:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/supportClasses/LayerDetails.html#ht...
You can try using HTTPService to retrieve the popup and then use the JSON decoder to parse it, but Flex has very limited HTML support, (unless you're using AIR), so you may want to try using this project instead:
http://code.google.com/p/flex-iframe/
TomSchuller
Dasa,
thank you for your answer.
I'm already using the "flex-iframe" solution.
Did you have plans to integrate the "htmlPopup" feature in your ArcGIS 2.0 FlexViewer?
Tom
BjornSvensson
Tom, support for htmlPopup is NOT likely in the next release of the ArcGIS Viewer for Flex, but it is something that might be in a subsequent release.
