Creating a PDF datagrid report from Search Widget
2161
08-24-2010 10:16 AM
AaronNash
I was trying to follow a previous thread from the old forum http://forums.esri.com/Thread.asp?c=158&f=2421&t=292246&mc=14#msgid912036 and am having problems. I added in the code for the search widget and needed to rename the function because there was a previous createrecorddata function, so I renamed it to createRecordData1 and have no errors in the search widget portion.
On the CreatePDF widget I am getting a 1152: A conflict exists with inherited definition mx.core:UIComponent.x in namespace public error.
   public function ArrayCollection(source:Array=selectedparcels):void
   //set up the Array that will be used to push featureSet data to DataGrid
   var tempArray:Array = new Array();
   //set up header for csvString;
   //var PrclKey:int = 0;
   //var Type:String = "";
   //var LegalDesc:String = "";
   var x:ArrayCollection = map.layers as ArrayCollection;
   var results : ArrayCollection = new ArrayCollection;
   for (var j:Number = 0; j < x.length; j++)
    var lay:Layer = x.getItemAt(j) as Layer;
    var layName:String = lay.name;
    if(lay.name.toLowerCase() == "selectedparcels")
     var gLay:GraphicsLayer = lay as GraphicsLayer
     var ga:ArrayCollection = gLay.graphicProvider as ArrayCollection;
     for (var i:Number = 0; i < ga.length; i++)
      //Now that I have that layer I can iterate through the individual graphics
      var g:Graphic = ga.getItemAt(i) as Graphic;
      //And get their attributes
      var infoData:Object = g.attributes;
      //I personally what to know if there is more than one graphic
      //selected and do something else if there is more than one
      //In my searchWidget I add several custom attributes to the graphic
      // ppin is one of them that you see here.
      //So now that you have the attributes you do what you want with them
      if (ga.length == 1)
       var xContent:String = infoData.content;
       var xTitle:String = infoData.title;
       var ZoningDesc:String = infoData.ZoningDesc;
       var Overlay:String = infoData.Overlay;
       var ZoneCode:String = infoData.ZoneCode;
       var ZoneKey:String = infoData.ZoneKey;
       var UDC_Zoning:String = infoData.UDC_Zoning;
       var Base:String = infoData.Base;
