JSON.encode(graphic:Graphic)
1158
05-04-2010 05:33 AM
TomSchuller
Hy,
I'm trying to encode a graphic object into a json string.
I got translated the geometry but the symbology is ignored.
var myGraphimyGraphic.geometry = new MapPoint(70000,71000);
myGraphic.symbol = new SimpleMarkerSymbol("cross");
var jsonStr = JSON.encode(myGraphic);
trace(jsonStr);
The jsonStr variable has the value:
  {"geometry":{"x":70000,"y":71000}}
Why is the symbology ignored in the JSON.encode method?
Tom
RobertScheitlin__GISP
Tom,
    I ran into the same issue and had to manually specify my symbology in my data before encoding. Maybe the API team can explain this limitation or agree to fix the issue, but until then here is what I did.
private function addGras():void
    drawAC = new ArrayCollection();
    var i:Number;
    var symTypeName:String = "";
    var symType:String = "";
    var symLType:String = "";
    var symFontE:String = "";
    var symSize:Number = 1;
    var symColor:Number = 0x000000;
    var symColor2:Number = 0x000000;
    var symWidth:Number = 1;
    var symText:String = "";
    var symAlpha1:Number = 1;
    var symAlpha2:Number = 1;
    var geomType:String = "";
    var geomSR:Number;
    var gname:String = "";
    for (i = 0; i < graphicsLayer.numGraphics; i++)
     var geomArray:Array = [];
     symText = "";
     var gra:Graphic = graphicsLayer.getChildAt(i) as Graphic;
     switch(gra.geometry.type)
      case Geometry.MAPPOINT:
          if (gra.symbol is TextSymbol) {
           var txtSym:TextSymbol = gra.symbol as TextSymbol;
           symTypeName = "TextSymbol";
           var txtFormat:TextFormat = txtSym.textFormat;
           if(useDefaultFont){
            symType = "Arial"
           }else{
            symType = txtFormat.font
           symText = txtSym.text;
           if (txtFormat.bold)
            symFontE += "B"
           if (txtFormat.italic)
            symFontE += "I"
           if (txtFormat.underline)
            symFontE += "U"
           symSize = Number(txtFormat.size);
           symColor = Number(txtFormat.color);
          } else {
           var ptSym:SimpleMarkerSymbol = gra.symbol as SimpleMarkerSymbol;
           symTypeName = "SimpleMarkerSymbol";
           symType = ptSym.style;
           symColor = ptSym.color;
           symSize = ptSym.size;
           symAlpha1 = ptSym.alpha;
           symColor2 = ptSym.outline.color;
           symAlpha2 = ptSym.outline.alpha;
           symWidth = ptSym.outline.width;
           symLType = ptSym.outline.style;
          geomType = "MAPPOINT";
          var pnt:MapPoint = gra.geometry as MapPoint;
          geomSR = gra.geometry.spatialReference.wkid
          geomArray.push(pnt);
          break;
         case Geometry.POLYLINE:
          var lineSym:SimpleLineSymbol = gra.symbol as SimpleLineSymbol;
          symTypeName = "SimpleLineSymbol";
          symType = lineSym.style;
          symWidth = lineSym.width;
          symAlpha1 = lineSym.alpha;
          symColor = lineSym.color;
          geomType = "POLYLINE";
          var polyline:Polyline = gra.geometry as Polyline;
          for (var i1:int = 0; i1 < polyline.paths.length; i1++)
           for (var j:int = 0; j < polyline.paths[i1].length; j++)
            var mp:MapPoint = polyline.getPoint(i1,j) as MapPoint;
            geomArray.push(mp);
          break;
         case Geometry.POLYGON:
          var polySym:SimpleFillSymbol = gra.symbol as SimpleFillSymbol;
          symTypeName = "SimpleFillSymbol";
          symType = polySym.style;
          symWidth = polySym.outline.width;
          symLType = polySym.outline.style;
          symAlpha1 = polySym.alpha;
          symAlpha2 = polySym.outline.alpha
          symColor = polySym.color;
          symColor2 = polySym.outline.color;
          geomType = "POLYGON";
          var poly:Polygon= gra.geometry as Polygon;
          for (var i2:int = 0; i2 < poly.rings.length; i2++)
           for (var j1:int = 0; j1 < poly.rings[i2].length; j1++)
            var mp2:MapPoint = poly.getPoint(i2,j1) as MapPoint;
            geomArray.push(mp2);
          break;
         case Geometry.EXTENT:
          var rectSym:SimpleFillSymbol = gra.symbol as SimpleFillSymbol;
          symType = rectSym.style;
          symWidth = rectSym.outline.width;
          symLType = rectSym.outline.style;
          symAlpha1 = rectSym.alpha;
          symAlpha2 = rectSym.outline.alpha
          symColor = rectSym.color;
          symColor2 = rectSym.outline.color;
          geomType = "EXTENT";
          var rect:Extent= gra.geometry as Extent;
          var mp3:MapPoint;
          mp3 = new MapPoint(rect.xmin, rect.ymin, gra.geometry.spatialReference);
          geomArray.push(mp3);
          mp3 = new MapPoint(rect.xmax, rect.ymax, gra.geometry.spatialReference);
          break;
     var gObj:Object = {
      geomtype: geomType,
      geomarray: geomArray,
      geomsr: geomSR,
      symtypename: symTypeName,
      symtype: symType,
      symsize: symSize,
      symcolor: symColor,
      symcolor2: symColor2,
      symwidth: symWidth,
      symtext: symText,
      symalpha1: symAlpha1,
      symalpha2: symAlpha2,
      cmenu: gra.contextMenu,
      symfonte: symFontE,
      symltype: symLType,
      gname: gra.name
     drawAC.addItem(gObj);
    if(!fr) fr = new FileReference();
    fr.save(JSON.encode(drawAC.source),"SavedGraphics.txt")
       graphicsLayer.clear();
TomSchuller
Robert,
I just completed my own JSON encoding.
It's trying to reusing the REST-JSON format of the AGS Server:
  http://<agsserver>:8399/arcgis/sdk/rest/symbol.html
Below you can find my code (textsymbol is incomplete).
Tom
            private function jsonEncodeGraphic(graphic:Graphic):String {
                var graObj:Object = new Object();
                graObj.geometry = graphic.geometry;
                graObj.symbol = encodeSymbol(graphic.symbol);
                return JSON.encode(graObj);
            private function encodeColor(color:uint, alpha:Number = 1):Array {
                var colorArray:Array = new Array();
                var alphaRestValue:uint = alpha * 255;
                var hexRep:String = color.toString(16);
                if (hexRep.length == 6) {
                    colorArray.push(new uint("0x" + hexRep.substring(0, 2)));
                    colorArray.push(new uint("0x" + hexRep.substring(2, 4)));
                    colorArray.push(new uint("0x" + hexRep.substring(4, 6)));
                } else if (hexRep.length == 4) {
                    colorArray.push(new uint(0));
                } else if (hexRep.length == 2) {
                } else {
                colorArray.push(alphaRestValue);
                return colorArray;
            private function encodeSymbol(symbol:Symbol):Object {
                var symbolObj:Object = new Object();
                if (symbol is TextSymbol) {
                    var textSym:TextSymbol = symbol as TextSymbol;
                    //not yet finished
                    symbolObj.type = "esriTS";
                    symbolObj.angle = textSym.angle;
                    symbolObj.color = encodeColor(textSym.color, textSym.alpha);
                    if (textSym.background)
                        symbolObj.backgroundColor = encodeColor(textSym.backgroundColor);
                    if (textSym.border)
                        symbolObj.borderLineColor = encodeColor(textSym.borderColor);
                    symbolObj.xoffset = textSym.xoffset;
                    symbolObj.yoffset = textSym.yoffset;
                    symbolObj.text = textSym.text;
                    return symbolObj;
                } else if (symbol is SimpleMarkerSymbol) {
                    var markerSym:SimpleMarkerSymbol = symbol as SimpleMarkerSymbol;
                    symbolObj.type = "esriSMS";
                    symbolObj.style = symbolObj.type + markerSym.style.substring(0, 1).toUpperCase() + markerSym.style.substring(1);
                    symbolObj.color = encodeColor(markerSym.color, markerSym.alpha);
                    symbolObj.size = markerSym.size;
                    symbolObj.angle = markerSym.angle;
                    symbolObj.xOffset = markerSym.xoffset;
                    symbolObj.yOffset = markerSym.yoffset;
                    if (markerSym.outline) {
                        var outlineObj:Object = new Object();
                        outlineObj.color = encodeColor(markerSym.outline.color, markerSym.outline.alpha);
                        outlineObj.width = markerSym.outline.width;
                        outlineObj.style = markerSym.outline.style;
                        symbolObj.outline = outlineObj;
                    return symbolObj;
                } else if (symbol is SimpleLineSymbol) {
                    var lineSym:SimpleLineSymbol = symbol as SimpleLineSymbol;
                    symbolObj.type = "esriSLS";
                    symbolObj.style = symbolObj.type + lineSym.style.substring(0, 1).toUpperCase() + lineSym.style.substring(1);
                    symbolObj.color = encodeColor(lineSym.color, lineSym.alpha);
                    symbolObj.width = lineSym.width;
                    return symbolObj;
                } else if (symbol is SimpleFillSymbol) {
                    var fillSym:SimpleFillSymbol = symbol as SimpleFillSymbol;
                    symbolObj.type = "esriSFS";
                    symbolObj.style = symbolObj.type + fillSym.style.substring(0, 1).toUpperCase() + fillSym.style.substring(1);
                    symbolObj.color = encodeColor(fillSym.color, fillSym.alpha);
                    if (fillSym.outline)
                        symbolObj.outline = encodeSymbol(fillSym.outline);
                    return symbolObj;
                Alert.show("Unknown SYMBOL type to convert to json: " + symbol);
                return null;
