Local map service not loading in SFV
933
05-05-2010 10:40 AM
MarcCavallaro
I've poked around a bit on the forum but didn't find a solution.  So here's my problem. I can't get my local map service to load correctly in the SFV via code.
I've added the rest url to Live Maps code block in confix.xml, yet when I run the application the map service shows up in the Live Maps list but there are no layers available.
However, If I add the map service using the Live Maps "AddService" button, using the same rest url that I placed in the code block. The service appears with layers and works correctly.
What am I missing?
RobertScheitlin__GISP
Supamackalicious,
   It sounds like the issue that is covered here.
here
Robert
MarcCavallaro
Yep, line 159 in MapManager.mxml needed to be commented out.  All is well. Thanks.
