is it possible to build flex applications with ArcGIS server9.2?
1055
05-31-2010 11:14 PM
srinivasreddy
Now i am working with ArcGIS Server 9.2 and Visual studio. Recently i saw some applications which are developed with Flex api.
So i want to change from .NET to flex.But i don't have the flex builder software. Through internet  i got a tool to called tofino plug in to integrate flex in Visual studio. Through this can i build flex applications in Visual studio. and is it possible to build flex application with ARC GIS server 9.2. or is it necessary Arc GIS server 9.3 or more.
please give me the information..............
thank you.........
RobertScheitlin__GISP
Srinivas,
   The REST endpoint that the Flex API uses was introduced at 9.3. So yes AGS Server 9.3 is required.
Here is the quote from the requirement page of the API
The ArcGIS API for Flex, both versions 1.x and 2.x, will work with any REST-enabled ArcGIS Server, i.e., ArcGIS Server 9.3 or later.
MarkDeaton
Esri Alum
The REST API that the Flex API depends on didn't come along until 9.3+. In theory you could still write a Flex app to use the SOAP services exposed by ArcGIS Server 9.2 and below. But (a) you wouldn't get the benefits of the nice ArcGIS Flex object model, and (b) in practice I've found that the Flex SOAP tools do a very poor job of building code from ArcGIS SOAP.
