Query not returning all features when using a graphic. Sample doesn't work either.
1324
05-26-2010 12:34 PM
BrendanLee
The code below works...most of the time. I want the user to draw a polygon, then use the graphic to select all the parcels it intersects. The selected set of parcels will then be buffered.
If a graphic is drawn that covers a large amount of parcels or has several vertices, the query only returns a portion of the parcels covered by the graphic. It's pretty random too in what it misses. I am simplyfing the polygon. The sample for selecting parcels does the same thing if a large area is defined.
I'm trying to build a notification program and there are many times when a large area needs to be defined. Any suggestions??
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
    xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:esri="http://www.esri.com/2008/ags"
    styleName="plain"
<mx:Script>
 <![CDATA[
  import com.esri.ags.tasks.Query;
  import com.esri.ags.tasks.QueryTask;
  import com.esri.ags.events.QueryEvent;
  import com.esri.ags.events.GeoprocessorEvent;
  import com.esri.ags.events.GeometryServiceEvent;
  import com.esri.ags.toolbars.Draw;
  import com.esri.ags.toolbars.Navigation;
  import com.esri.ags.tasks.FeatureSet;
  import com.esri.ags.geometry.Geometry;
  import com.esri.ags.geometry.Polygon;
  import com.esri.ags.geometry.Extent;
  import com.esri.ags.SpatialReference;
  import com.esri.ags.Graphic;
  import com.esri.ags.events.DrawEvent;
  import com.esri.ags.layers.GraphicsLayer;
  import com.esri.ags.tasks.BufferParameters;
  import mx.rpc.events.FaultEvent;
  import mx.rpc.AsyncResponder;
  import mx.collections.ArrayCollection;
  import mx.controls.Alert;
  import mx.events.ItemClickEvent;
 private var graphicParcels:Array;
 private function itemClickHandler(event:ItemClickEvent):void
  tbb.selectedIndex = -1;
  myGraphicsLayer.clear();
  parcelGraphicsLayer.clear();
  switch (event.index)
   case 0:
    drawToolbar.activate(Draw.POLYGON);
    break;
   case 1:
    drawToolbar.activate(Draw.FREEHAND_POLYGON);
    break;
 /* Required with a DrawEnd event.*/
    private function onDrawEnd(event:DrawEvent):void
  var graphic:Graphic = event.graphic;
  drawToolbar.deactivate();
  // Add graphic to the graphics layer
  myGraphicsLayer.add(graphic);
  var geometryPolygon:Polygon = graphic.geometry as Polygon;
  myMap.centerAt(geometryPolygon.extent.center);
  // Simplify the graphic so selection will work properly
  myGeometryService.simplify([graphic]);
 private function simplifyCompleteHandler(event:GeometryServiceEvent):void
  findParcels(event.graphics[0]);
 private function findParcels(graphic:Graphic):void
  // clear the graphics layer
  //myGraphicsLayer.clear();
  // Create query to select parcels that intersect drawn shape
  var parcelQuery : Query = new Query();
  parcelQuery.returnGeometry = true;
  parcelQuery.geometry = graphic.geometry;
  parcelQuery.outFields = ["PARCEL", "STRNO", "STRDIR", "STRNAME", "STRTYPE"];
  parcelQuery.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
  parcelQuery.outSpatialReference = myMap.spatialReference;
  parcelQueryTask.showBusyCursor = true;
  parcelQueryTask.execute(parcelQuery, new AsyncResponder(onParcelResult, onParcelFault));;
 private function onParcelResult(featureSet:FeatureSet, token:Object = null) : void
  if (featureSet.features.length != 0)
   // Create an extent rectangle that will cover all the parcels selected
   var unionExtent : Extent;
   var myFirstGraphic : Graphic = featureSet.features[0];
   unionExtent = Polygon(myFirstGraphic.geometry).extent;
   for each (var myGraphic : Graphic in featureSet.features)
                myGraphic.symbol = (parsym);
    // Adds parcel number and address as tool tip
    myGraphic.toolTip = "Parcel: " + myGraphic.attributes.PARCEL.toString()
     + "\nAddress: " + myGraphic.attributes.STRNO + " "
     + myGraphic.attributes.STRDIR.toString() + " "
     + myGraphic.attributes.STRNAME + " "
     + myGraphic.attributes.STRTYPE;
    parcelGraphicsLayer.add(myGraphic);
    // Expand map extent to all selected parcels
    unionExtent = unionExtent.union(Polygon(myGraphic.geometry).extent );
   // Zoom map out a bit
   //myMap.extent = unionExtent.expand(2);
   myMap.extent = unionExtent.extent;
   // Pass all selected parcels to array to be used by buffer function
   graphicParcels = ArrayCollection(parcelGraphicsLayer.graphicProvider).toArray();
  else
   Alert.show("Error selecting parcels");
 private function onParcelFault( info : Object, token : Object = null ) : void
  Alert.show( info.toString() );
 private function bufferFeature():void
  var bufferParameters:BufferParameters = new BufferParameters();
        bufferParameters.features = graphicParcels;
  bufferParameters.distances = [ 500 ];
  bufferParameters.unionResults = true;
  bufferParameters.unit = BufferParameters.UNIT_FOOT;
  bufferParameters.bufferSpatialReference = new SpatialReference(32007);
  myGeometryService.addEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler1);
  myGeometryService.buffer(bufferParameters);
  function bufferCompleteHandler1(event:GeometryServiceEvent):void
   for each (var graphic:Graphic in event.graphics)
    graphic.symbol = sfs;
    var buffExtent : Extent;
    buffExtent = Polygon(graphic.geometry).extent;
    myMap.extent = buffExtent.expand(2);
            myGeometryService.removeEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler1);
 private function onGeomFault(fe:FaultEvent):void
  Alert.show("Unexpected fault:\n" + fe.toString());
    </mx:Script>
  <!-- Parcel query -->
    <esri:QueryTask id="parcelQueryTask"
        url="http://cohntfs82/ArcGIS/rest/services/public/Parcels/MapServer/0" />
  <!-- Geometry Service used to project point for Google Street View -->
    <esri:GeometryService
            id="myGeometryService"
            simplifyComplete="simplifyCompleteHandler(event)"
            fault="onGeomFault(event)"
            showBusyCursor="true"
            url="http://cohntfs82/ArcGIS/rest/services/Tools/Geometry/GeometryServer"/>
    <!-- Symbol for Polygon -->
    <esri:SimpleFillSymbol id="sfs" alpha="0.4">
        <esri:SimpleLineSymbol color="#FF0000" width="2" alpha=".6" style="solid"/>
    </esri:SimpleFillSymbol>
    <esri:SimpleFillSymbol id="parsym" alpha="0.6" color="#f1f57c">
    <esri:Draw id="drawToolbar"
        map="{myMap}"
        fillSymbol="{sfs}"
        drawEnd="onDrawEnd(event)" />
    <mx:ControlBar width="100%" horizontalAlign="center">
        <mx:VBox borderStyle="solid" horizontalAlign="center" width="172">
            <mx:ToggleButtonBar id="tbb"
                creationComplete="tbb.selectedIndex = -1"
                itemClick="itemClickHandler(event)"
                toggleOnClick="true">
                <mx:dataProvider>
                    <mx:Object id="p0" label="Polygon"/>
                    <mx:Object id="p1" label="FreeHand"/>
                </mx:dataProvider>
            </mx:ToggleButtonBar>
        </mx:VBox>
        <mx:Button label="Buffer" id="buttonBuffer" click="bufferFeature()"/>
    </mx:ControlBar>
    <esri:Map id="myMap" logoVisible="false">
        <esri:ArcGISTiledMapServiceLayer
            url="http://cohntfs82/ArcGIS/rest/services/public/basemap/MapServer" />
        <esri:GraphicsLayer id="myGraphicsLayer"/>
        <esri:GraphicsLayer id="parcelGraphicsLayer"/>
    </esri:Map>
</mx:Application>
DasaPaddock
BrendanLee
Dasa,
Thanks for the reply. I followed the directions for increasing the max records and set it to 5000. I'm still getting the same results.
DasaPaddock
If you go to your query page, like this one:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Portland/ESRI_LandBase_WebMercator/MapSer...
and in the Where field, enter "1=1" and set Return Geometry to No, do you get more than 500 results? If not, you may need to contact ESRI support at http://support.esri.com
BrendanLee
Dasa,
I did the query and it still returns only 500. I stopped and restarted the service several times. I also did an iisreset. Still no luck.
Is this a bug or is something not set up correctly on my server?
